Here's the sites you may see in NY:
Buffalo(Dansville) FAA ID: DSV Type: ARSR-1E
Scan Time: 10
Max Range 200
N 42.63836055555556, W 77.65306
Newark FAA ID: EWR Type: ASR-9
Scan Time: 5
Max Range: 60
N 40.673273611111114, W 74.18571277777778
White Plains FAA ID: HPN Type: ASR-9
Scan Time: 5
Max Range: 60
N 41.072786111111114, W 73.71541111111111
New York FAA ID: JFK Type: ASR-9
Scan Time: 5
Max Range: 60
N 40.63962222222222, W 73.76642777777778
Du Bois FAA ID: QCF Type: ARSR-3
Scan Time: 12
Max Range: 200
N 41.07026666666667, W 78.55041111111112
North Truro FAA ID: QEA Type: ARSR-4
Scan Time: 12
Max Range: 250
N 42.03455 W 70.05439
Cummington FAA ID: QHA Type: AN/FPS-67B
Scan Time: 12
Max Range: 200
N 42.47472 W 72.96799
Gibbsboro FAA ID: QIE Type ARSR-4
Scan Time: 12
Max Range: 250
N 39.82477055555555, W 74.95414333333333
The Plains FAA ID: QPL Type: ARSR-3
Scan Time: 12
Max Range: 200
N 38.88225 W 77.70308333333334
Benton FAA ID: QRC Type: AN/FPS-67B
Scan Time: 12
Max Range: 200
N 41.35740416666667 W 76.29298777777778
Riverhead FAA ID: QVH Type: ARSR-4
Scan Time: 12
Max Range: 250
N 40.87868 W 72.68710
Utica (Remsen) FAA ID: QXU Type: ARSR-4
Scan Time: 12
Max Range: 250
N 43.34550 W 75.24897
Newburgh (Stewart) FAA ID: SWF Type: ASR-9
Scan Time: 5
Max Range: 60
N 41.49058333333333 W 74.10566388888888
St. Albans FAA ID: QHB
Scan Time: 12
Max Range: 200
N 44.78172 W 73.06564
Bucks Harbor FAA ID: QYA
Scan Time: 12
Max Range: 250
N 44.62943 W 67.39537
Manchester FAA ID: MHT
Scan Time: 5
Max Range: 60
N 42.950013 W 71.299194
If you manage to correlate any of these to their correct II/SI identifiers, please share.
Reason: Added MHT, Removed rogue smiley
