joeuser
The Wretched
This is my non-scientific review of this antenna. Found it on eBay for 40 USD. Seller uses ' lz2rr ' name.
As per the auctions description:
>6dBi gain, colinear 4 elements , PCB build, DC grounded
! more than 3 times better coverage compared with 5/8 antenna !
European made quality at resonable price
Affordable coverage & redundancy
Up to 250 NM range with straight view (attached to microADSB IP BULLION receiver)
N female type directly mounted connector
Perfect for use with SBS, Radarbox, microADSB, RTL ADS-B receivers
Mounting kid included.
The 1090MHz ADS-B Omni Directional antenna offered by ANTENI.NET Ltd. is constructed of gray color UV-stable base. It has type N female connectors for direct connection to ADS-B receiver. The horizontal pattern is a full 360 degrees with gain flatness better than 1dB. Because of it’s slimline design and low wind loading characteristics, it is very easy to use with any ADS-B receiver on any place and wether conditions. Mounting brackets for 1"1/4 pipe hor&vert included. Vertically and horizontally adjustable.
Frequency: 1090 MHz
Gain: 6dBi
Azimuth: 360 deg
Impedance: 50 Ohm
Max Power: 50 W
VSWR 1,5:1
Vertical polarization
Wind Survival: 125 km/h
Temperature range: -45 to 60 deg C
Length: 70cm
Weight: 540g
Conektor: N(f)
Box dimensions: 10x10x76 cm
* Coaxial cable is not included in the set. Please, contact us if you need.
I contacted the seller ' lz2rr ' with questions about the auction & the responses were quick, informative, very pleasant, & understandable (so not sure about the grammatical mistakes or errors in the auction description). The seller also vends other products of interest to our hobby.
I ordered this on the evening of June 13 2015 & my trusty USPS official dropped it off today June 24 2015.
The box has considerable wear on it & is very thin & soft but hopefully it made it OK.
NOTE: I am not being compensated in any way shape or form for this review. I have ZERO financial interest here. I'm just a guy that bought this antenna off eBay & reviewing it for the community to benefit from...
Pictures follow
Frequency: 1090 MHz
Gain: 6dBi
Azimuth: 360 deg
Impedance: 50 Ohm
Max Power: 50 W
VSWR 1,5:1
Length: 70cm
Weight: 540g
Conektor: N(f)
Pictures follow
