Getting out of all radio but aircrAft
hfflunki
West Michigan
So I just loadeD up th CB stuff for goodwill and programmed the acars freq in the scanner I read you have to go through manually because it doesn't here a synch tone and I put in all 15 available I'm in north west mi I can hear milwaki occasional.if any one wants to heplease a guy get a start in acars please help. I'm using a ws1025 for acars and an iPad to decode (hopfuLily) I ordered a Chinese air radio but it won't be here for some time it's a tso I bought that caus I didn't like all the extra options on my r2 I sold or my aor mini
Thanks 73
RFI-EMI-GUY
You cant just scan in carrier squelch mode? I suppose you could cobble up a tone detector and and wire it accross the noise squelch somehow to stop scan. But it would have to react to the data as well.
mm
oregon
Man RFI-EMI-GUY You are good at copying and deciphering borderline readable text.
You are like a really good police dispatcher picking up a mobile unit out of the noise with a 3db Sinad or lower signal.
Me, I only copied 25% of what he was trying to say.
hfflunki
West Michigan
Well thanks I mostly. Like listening to elevation and carrier while looking at plane. Finder and radar box but this experiment isn't working well
hfflunki
West Michigan
set up a decoding station with my I pad mixer scanner and 909x
RFI-EMI-GUY
Is your receiver in the AM mode? APRS is FM while ACARS is AM as I recall. Also your antenna needs to be outside and away from any computer noise source.
hfflunki
West Michigan
Well it's in am and I can hear it synch but nothing decodes even put small squalch on that didn't help wow there my first hit
RFI-EMI-GUY
Looks like you got something;
To start, run the squelch wide open so not to miss any preamble. Also this might be a slow day for air traffic. You might also check the web for ACARS test files. They will be audio files with tones, you can load them in a smartphone and play them into your ipad to check settings. The levels of course will depend on your scanner audio levels.
http://www.universal-radio.com/catalog/decoders/acarsweb.pdf
https://www.youtube.com/watch?v=K5VORWa7jHw
https://commons.wikimedia.org/wiki/File:Acars_sample.ogg
http://www.kb9ukd.com/digital/acars.wav
hfflunki
West Michigan
Thanks for all the help ivested in a 125at and took out the mixer still learning but this scanner and my 909x along with my iPad are everywhere with me along with nesesory assessorys
hfflunki
West Michigan
No I lock out the data the problem is I'm in a low location and using an iPad or iPhone and have to have the volume just right
