Go Back   The RadioReference.com Forums > Topic Specific Forums > Aircraft Monitoring Forum
Aircraft Monitoring Forum This is the place to discuss monitoring aircraft communications, including ACARS digital transmissions.
Old 11-01-2008, 12:57 AM
737mech's Avatar
Question Pairing up the tower freqs VHF/UHF
Is there a proven way or formula to figure out why an airport using both VHF and UHF freqs for the tower freqs? Is there a reason or method? Say a Military base is using VHF xxx.xxxx and UHF xxx.xxxx ok, well sometimes when monitoring you can catch the tower better on UHF and the Planes on VHF? Most of the published airports have both VHF and UHF freqs listed for the tower and approach/departure etc. They seem very random and without methodology to pair the freqs? Who decides what freqs are assigned to an airport? This would be good info if you thought you were only getting half the conversation.
Old 11-02-2008, 06:54 PM
DaveNF2G's Avatar
VHF frequencies are for civilian aircraft (and some military). UHF frequencies are exclusively for military use.
There is no fixed relationship between VHF and UHF frequencies at any facility. The FCC licenses VHF, and NTIA allocates UHF.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 11-03-2008, 01:16 PM
Not sure about these days, but it used to be that US Navy aircraft had only UHF capability.
Most civilian towers have UHF capability, but the frequency is published only in the FLIP/DOD publications and not on civilian charts.
A phone call to your local tower should help discover the frequency.
Old 11-03-2008, 03:16 PM
I have sectional, WAC, and terminal charts that list both VHF and UHF frequencies on them.
12 volt radios are for wimps. Real radios can kill you.
Old 11-03-2008, 03:28 PM
DPD1's Avatar
If you're asking if there's a predictable formula to matching the two, like some ham repeaters and other systems have... then no. They decide who talks where based on a lot of factors, but there's no predictable split between the bands on air.
Dave
www.DPDProductions.com
Antennas & Accessories for the RF Professional & Radio Hobbyist
Old 11-03-2008, 04:01 PM
zz0
Good show! The older charts did not display the UHF frequencies.
Old 11-05-2008, 05:48 PM
KE5CCA's Avatar
I do not know if that is entirely true. According to the "Facility Transmitting Authorization" hanging on the wall here, it says:
In accordance with authority granted the Federal Aviation Administration by the National Telecommunications & Information Administration through the Interdepartmental Radio Advisory Committee, this Authorization is issued for the operation of this facility.
Since there are VHF and UHF frequencies listed, it would seem that the FAA, through Spectrum Management, is responsible for assignments in both bands.
Old 11-06-2008, 05:01 PM
DaveNF2G's Avatar
How old is that notice? I'm not sure that IRAC exists any more.
Old 11-06-2008, 05:15 PM
It does.
http://www.ntia.doc.gov/osmhome/irac.html
Tom
Old 11-06-2008, 06:34 PM
Send a message via AIM to Lynch_Christopher
On the NTIA website where does it say what frequencies are allocated to each facility.
Old 11-07-2008, 02:29 PM
DaveNF2G's Avatar
It doesn't. Federal frequency allocations have been Classified since 1982.
Old 11-08-2008, 12:37 AM
So even the air traffic control frequencies allocations are classified?
Old 11-08-2008, 12:40 PM
DaveNF2G's Avatar
ATC on VHF and possibly UHF are public record as long as they are licensed through the FCC.
IRAC allocations were classified by President Reagan's Executive Order in 1982.
Old 11-13-2008, 01:44 PM
Approach plates have the UHF frequencies listed where they exist.
http://204.108.4.16/d-tpp/0811/00026I10C3.PDF
Note that there's only one UHF frequency in use for both local control and ground control. Radar facilities will have a UHF pairing for every sector in use. Low altitude en-route charts will have both VHF/UHF frequencies listed.
A tower at a smaller airport isn't likely to have UHF radios in place unless it sees some military traffic periodically.
Old 11-18-2008, 04:51 PM
Or maybe the question is: Which tower VHF frequency is simucasted to which tower UHF frequency?
Old 11-19-2008, 01:16 AM
unitcharlie's Avatar
Kentucky DB Admin...
airnav.com lists UHF freqs for airports with military traffic in Kentucky....
Co-Founder/Active Member of the Central Kentucky Monitoring Team
Opinions based on MY experiences, real AND delusional...
WX4LEX
unitcharlie@radioreference.com
Twitter: CollierLEX18
Old 11-20-2008, 10:51 PM
It depends on which controller is working the airplane. Each position has the ability to select several frequencies (including other positions) from a panel, which may be either physical switches in older facilities or a touch screen in ones that have had some or all of their equipment updated in the past 8-10 years.
For a facility like Atlanta that has little military traffic (they'd only do it in an emergency most likely, Dobbins ARB is about 15 miles NW) the tower or ground position would probably get a heads up over the shout-line from the approach control letting them know that the aircraft they're about to get is UHF only.
Old 11-21-2008, 01:47 PM
DaveNF2G's Avatar
They should not need a "heads up" to hear an emergency (or any other) call. Any facility that lists an operating frequency should be monitoring that frequency.
Old 11-21-2008, 07:42 PM
Not necessarily. At towers within class B/C airspace may not monitor anything but 243.0 because of interference over the UHF radios. I had the supervisor at one of the nearby ATC facilities tell me that they try to work what military traffic they do get on VHF if at all possible.
Old 11-22-2008, 09:35 AM
coldbricks's Avatar
Albany NY Supervisor
Send a message via AIM to coldbricks
any time that frequency is keyed up alarms would go off. Its very similar to transponder codes that trigger alarms.
Similar Threads
120 foot tower: questions. zguy1243 Antennas and Coax Forum 7 09-26-2008 11:43 AM
Double Eagle II Gets Traffic Control Tower abqscan New Mexico Radio Discussion Forum 0 09-06-2008 09:31 AM
New Tower sites on KSICS in South Central n0lqt Kansas Radio Discussion Forum 11 05-21-2008 10:02 PM
Western North Carolina vhf/uhf freqs N8IAA Military Monitoring Forum 1 06-16-2006 10:09 PM
Discrete VHF/UHF Aviation freqs JoeH Aircraft Monitoring Forum 7 03-09-2006 10:49 AM
