Aircraft programming strategy for inexpensive scanner?
What is your favorite programming strategy for the inexpensive conventional scanner with the typical bank/channel setup?
Ok, this is kind of a loaded question - I'm familiar with aircraft scanner programming, but when I brought home an inexpensive RS Pro-135 handheld as a general-aviation backup, I realized just how poor the out-of-box experience could be for a budding aircraft monitoring enthusiast.
First on the list: Other than ditching the rubber duck, the biggest problem I see is that doing a "service search" on the aircraft band is so slow that you miss most of the action and might even assume the scanner is dead or there isn't any activity. Almost as bad is dumping 200 channels into it and slogging through all of the channels and missing comms. Don't waste your time. Instead, head straight to the RadioReference database and get the channels for your area programmed into memories and optimize the banks.
Generally, I program my channels with known nearby frequencies, and include duplicates like the same air-to-air channels among all the banks. I don't mind wasting a few channels when I'm doing multi-bank monitoring due to the fact that the comms are so short I'll hit that duplicate frequency even faster. The banks themselves are dedicated to areas I'll be sure to hear things in, like when I'm at work, school, or elsewhere.
Other than that, I turn off the channel delay, as I'm not interested in hearing the "good night" replies, and want to get to the next active channel as fast as possible. Works for me.
So how do you have yours programmed on a conventional scanner? Do you put specific airports into banks, or separate them by high-level / low-level, aircraft vs helicopters, or do you prefer to do it geographically?
