Go Back   The RadioReference.com Forums > Topic Specific Forums > Aircraft Monitoring Forum
Aircraft Monitoring Forum This is the place to discuss monitoring aircraft communications, including ACARS digital transmissions.
Old 07-04-2009, 11:14 PM
zguy1243's Avatar
Send a message via AIM to zguy1243
Default SBS-1E 1090Mhz Antennas
I am putting a order in for a SBS-1E this week and I was wondering if anyone on the group is using the 1090Mhz antenna that Dave is selling over at DPD. Would like to get some good range with the box and make use of a good tower mounted fixed antenna and preamp combo. Anyone that using something different than the factory antenna I would to hear about your setup. And from what I have found out so far the SBS-1E is the clear choice over the airnav box for various reasons that have came to light.
Jody
Listening To The Skies:
Watkins Johnson 8617-B
Watkins Johnson 9518BE
Racal RA6790/GM
Racal RA2309B
AN/URC-110
BC895XLT
Pro-2042
Pro-2045x4
BC898T
www.Signal-Intelligence.com
Old 07-05-2009, 01:05 AM
Thumbs up
Originally Posted by zguy1243 View Post
I am putting a order in for a SBS-1E this week ...
Welcome to the club!
... and I was wondering if anyone on the group is using the 1090Mhz antenna that Dave is selling over at DPD.
I've been a big fan of all of Dave's antennae for many years, and helped to encourage him to do one for these boxes -- they work on both the SBS-1 and the RadarBox; make sure to tell him which version you want to get the right pigtail, BNC (SBS-1) or SMA (RadarBox or SBS-1e/-1er). I'm very happy with the results on my main box and have deployed a few others; several friends also have them and report great results. His workmanship is excellent, far better than the experiences i've had with the major antenna makers in the amateur world like Diamond and Comet. I think I have at least one of each of the "stock" antennas available (the mag mount; the table-top version with the removable disk-shaped ground plane; the trunk-clip version; and the mast mount with 3-pronged ground plane ... am I missing any of the collection?) and they all have their purposes. They all perform about the same as each other (modulo the mount), and as usual, if you can get them up high and have high-quality cable running to them, they work well. Dave's is a different design and in the common case -- where your mounting location isn't going to be perfect -- it can add some significant benefit. I know that the limits of my reception are much different now than when I was using a stock antenna, pulling in hits from locations and distances that I wouldn't have guessed from looking at topo maps.
And finally: Dave is "one of us" -- he's a long-time milcom listener and adds a lot to the community through his postings and his website that's focussed on the Flight Test segment of the hobby. I think the DPD antenna is a great addition to a Mode-S/ADS-B monitoring setup at a more than fair price. FWIW, I'm also a big fan of what I think is the only made-for-milcom log-periodic antenna, also available from him. Dave doesn't pay me to say good things about his stuff, though I should probably pay him more for the support he's given me over the years (like the time I proudly sent him a photo of my mounting of one of his LPs and he calmly pointed out that I might have mounted it upside down ... but I digress.
Old 07-05-2009, 03:28 AM
brandon's Avatar
+1 for the DPD antenna. I have one and it works great!
Old 07-05-2009, 03:56 AM
I'm also using Dave's ADS-B antenna.
I got it since I also enjoyed reading Dave's posts in this hobby on RailScan or Aircraft groups.
You can also read other reviews from other SBS-1 users on this topic thread.
DPD Productions Antenna - 5 pages so far for this antenna.
http://www.kinetic-avionics.co.uk/fo...pic.php?t=9987
Old 07-23-2009, 08:58 PM
I modified a Maxrad 800 mhz PVC base antenna. I cut some off the top and bottom of the element in 1/8" increments and using a network analyzer and a friend whom knows how to operate the analyzer was able
to tune it within about 15 min.
I then used an old 800-1000 mhz TX RX preamp and set it for 1050 mhz because they are plenty broad anyway.
This is mounted on a tower up about 70' and feed with 1/2" helax.
I can regularly see out about 250 nm except to the southeast where I suspect I have some sheilding from hills off about 30 to 50 miles.
"Never enough time for radio"
Old 07-24-2009, 11:16 PM
Thumbs up DPD Antenna
I also have a DPD Antenna for my Airnav Radarbox and it works great! I got very fast shipping, wasn't expecting it as fast as it came.
73, Rex
Old 08-05-2009, 07:38 AM
What is available to "listen" to on 1090 MHz?
Old 08-06-2009, 10:58 PM
JLM7424's Avatar
Jody
Sorry not running any of this but thought This might be of interest
ADS-B • RADAR BOX + SBS-1 1090 MHz ADS-B Mode S Aviation Radar Transponder Antenna for SBS1
Matt.
My Signal Interceptors.... | Yupiteru MVT-7100 | Psr-600 | Bcd-396T |
Similar Threads
RR Members Commonly Used Base Antennas tonsoffun Antennas and Coax Forum 0 03-15-2009 02:40 PM
Add antennas on a unit bas phone wireless panasonic Gremlins Antennas and Coax Forum 1 02-14-2009 04:48 PM
Two antennas to one radio kc8zdf Antennas and Coax Forum 2 05-20-2007 05:52 AM
Got Antennas? yaesumofo Antennas and Coax Forum 5 05-10-2006 12:43 PM
Questions and Answers about wireless phones Radiorick Tavern Archives 10 12-23-2004 06:11 PM
