Go Back   The RadioReference.com Forums > Topic Specific Forums > Aircraft Monitoring Forum
Aircraft Monitoring Forum This is the place to discuss monitoring aircraft communications, including ACARS digital transmissions.
Old 07-12-2009, 02:41 PM
Default I can never hear Cleveland Center
I'm in Michigan and I hear planes calling Cleveland Center telling them they are at flight level 230 or something, but I never hear the center respond. Do I have to be close to te center?
Old 07-12-2009, 03:40 PM
shaft's Avatar
Find a local RCAG site and program it into your scanner. You will for sure hear Cleveland center.
From the link above, figure out which site is closest to you. You dont need to program all of them in your scanner.
Old 07-14-2009, 12:09 AM
cool thanks.
Old 07-14-2009, 09:59 AM
eorange's Avatar
In my experience, you still need to be right on top of the RCAG. The RCAGs don't have any more power, or a different radiation pattern, than the center w/ respect to hearing them on the ground. The RCAGs simply provide more coverage for the planes in the air, along with serving as backup sites.
I live about 20 miles from the Chardon RCAG, and no way can I pick up the ground comms from my house. So one day I drove out to that RCAG. I only started hearing ground comms when I was about 1 mile away.
Old 07-14-2009, 12:56 PM
EMD91123's Avatar
Send a message via ICQ to EMD91123 Send a message via AIM to EMD91123 Send a message via MSN to EMD91123 Send a message via Yahoo to EMD91123
Depending on the frequency and what it is being used for it may determine reception range. Maybe it is used as a low level sector freqnency that does not need great transmitter power. Whereas high level sectors in my experience you can get pilot/controller about 20 miles out from the transmitter(RCAG). What freq iis it if I may ask ???? If you want to get a good 150-180 mile range on high altitude you will need to plug in all the listed frequencies. Low level at 16000-20000 feet probably a good 130 mile range.
Tampa Bay Florida
Mostly listen to AIRCRAFT AND ARTCC
Old 07-14-2009, 01:13 PM
eorange's Avatar
Not sure who you were asking, but here's the details of the Chardon RCAG, by me.
By the way, I never dug into this - what exactly does low, high, & ultra high mean? Do those refer to altitude ranges, and if so, what are the altitudes? Does it matter how far away the plane is from the center, as the crow flies? I know you gave some details in your previous post...
CHARDON
120.7750 LOW DISCRETE
298.9500 LOW DISCRETE
Old 07-14-2009, 02:53 PM
shaft's Avatar
Low Altitude = Up to 23,000ft
High Altitude = 23,000ft to 33,000ft
Ultra High Altitude = Above 33,000ft
Old 07-14-2009, 04:01 PM
EMD91123's Avatar
beat me to the puch shaft I see. Ultra if I am not mistaken runs above anywhere between 340-370. I'll scan and post a copy of the sectors when I am at home on my home set.
Old 07-14-2009, 04:43 PM
thenewsden's Avatar
Quick question. Looking at the RCAG list, how do you know where the transmitter is located. I live in ZNY coverage area, but from the names on the RCAG list doesn't give me a clue where they are located? Thanks.
-Lee
http://thenewsden.wordpress.com
Twitter: @thenewsden
Old 07-14-2009, 06:49 PM
w0fg's Avatar
Are we talking about aircraft or the ground station?? If it's the ground station, you'll need to be within 10-15 miles. Aircraft, on the other hand, can be heard out to 150-200 miles if they're up above 33K ft, less distance at lower altitudes as previously noted.
Rick
"The King has note of all that they intend, by interception which they dream not of. "
Henry V, Act ll, Scene 2.
Old 07-14-2009, 11:22 PM
shaft's Avatar
Barnstable looks to be the closest one to you
Originally Posted by FreqOFNature.com
BARNSTABLE
125.9250 HIGH OCEANIC
135.8000 HIGH OCEANIC
284.7500 HIGH OCEANIC
381.6000 HIGH OCEANIC
Old 07-15-2009, 09:59 AM
EMD91123's Avatar
As promised
Old 07-15-2009, 10:10 AM
EMD91123's Avatar
And Low Sectors
Old 07-15-2009, 04:44 PM
thenewsden's Avatar
Actually I think that Big Flat is the closest one to me. I only say that because if I travel south approx. 10 miles I am able to pick up both the low and high sector for that transmitter. I was just curious if there is a way to tell where they are located. Thanks.
-Lee
-Lee
Old 07-16-2009, 09:00 AM
EMD91123's Avatar
KZOB CLEVELAND ARTCC
Old 07-16-2009, 11:41 AM
eorange's Avatar
I had found the actual location on freqofnature.com, but their database link doesn't seem to be working:
Freq Of Nature Databases
Old 07-18-2009, 10:50 AM
thenewsden's Avatar
I am not able to get that link to work either. It must not be a valid link any longer.
-Lee
Old 07-18-2009, 02:14 PM
BMT BMT is offline
Default Kzob rcag
These are the LAT/LON for the RCAG.
ALGONAC
N082-31-59.670W297119.670
ALTOONA
N078-34-34.060W282874.060
BELMONT
N081-01-40.350W291700.350
BLOOMINGVILLE
N082-42-27.000W297747.000
BRADFORD
N078-37-09.090W283029.090
CHARDON
N081-09-47.360W292187.360
OBERLIN,OH
N082-12-17.550W295937.550
CLEVELAND(BRECKSVILLE
N081-41-00.650W294060.650
DANSVILLE
N077-39-10.980W279550.980
DETROIT
N083-28-27.060W300507.060
DETROIT NORTH
N083-21-59.750W300119.750
DUBOIS
N078-53-56.000W284036.000
DUNKIRK
N079-16-27.150W285387.150
FINDLAY
N083-39-59.750W301199.750
FLINT
N083-44-27.840W301467.840
HOLLAND
N078-34-11.080W282851.080
JACKSON
N084-27-33.850W304053.850
JACKSON
LITCHFIELD
N084-42-17.860W304937.860
MANSFIELD
N082-30-14.600W297014.600
MOON TOWNSHIP
N080-13-25.210W288805.210
MORGANTOWN
N079-51-37.240W287497.240
MOUNT HOPE
N081-45-59.470W294359.470
PARIS
N081-08-54.360W292134.360
PITTSBURGH(OAKDALE)
N080-09-23.900W288563.900
SAGINAW
N084-04-33.930W302673.930
SANDUSKY
N082-42-31.650W297751.650
WARREN
N079-15-49.160W285349.160
WATERFORD
N080-01-25.190W288085.190
WATERVILLE
N083-38-19.160W301099.160
WAYLAND
N077-36-58.960W279418.960
BMT
Why would one believe anything that involved a group of intellectuals throwing bat dung into a candle seeking enlightenment
Old 07-24-2009, 10:07 PM
rcool101's Avatar
Default Cleve cntr
Did you ever try to here it on the web? Go to this link and go all the way to the bottom of the page. I know Pitts rcvr for Cleve Centr works
U.S. Class D Airport and ARTCCC Feeds | Live Air Traffic Control Audio Feeds | LiveATC.net
BCD396T GRE PSR 600 BC246T BC780XLT BC245XLT
Similar Threads
How to hear P25 on mixed-mode Motorola system? Gilligan GRE Scanners 8 03-05-2009 09:15 PM
pro-106 only hear dispatch nothing else forrest12 Radio Shack Scanners 1 02-15-2009 07:30 PM
Anyone hear all four Fort Hood P25 sites? cws Texas Radio Discussion Forum 3 01-10-2009 04:17 PM
Why can I hear the local police on an FRS frequency? diveben General Scanning Forum 13 09-26-2006 05:07 PM
Orange County area, what can you hear, type of scanner etc.. PatriciaInCA Greater Los Angeles & Inland Areas Discussion 14 09-10-2004 05:03 PM
