Go Back   The RadioReference.com Forums > Topic Specific Forums > Aircraft Monitoring Forum
Aircraft Monitoring Forum This is the place to discuss monitoring aircraft communications, including ACARS digital transmissions.
Old 09-05-2009, 02:07 PM
thenewsden's Avatar
Default Looking for Center Frequencies
I will be traveling primarily Interstate 81 South from Mechanicsburg, PA into Tennessee. I would like to monitor the center frequencies while enroute. Is there someway to find out what frequencies an aircraft flying the same route would be handed off to along the route? Thanks for any help.
-Lee
http://thenewsden.wordpress.com
Twitter: @thenewsden
Old 09-05-2009, 03:01 PM
FLRAILMAN's Avatar
Default PA. to TN. ARTCC handoff freq's
Check the RR database, that should help, it appears to be very accurate. Happy hunting.
FLRAILMAN
Old 09-06-2009, 06:07 PM
thenewsden's Avatar
Thanks for the info. I was hoping someone had a source where I could find geographically where the individual sectors are located. I had checked out the RR Database but it doesn't give any info to where the sectors are located. I know their names gives clues but I'm not familiar with the area that well.
-Lee
Old 09-06-2009, 07:37 PM
Bucko's Avatar
This may help some but I see some of the freqs maybe out dated, it does have a rough map for their coverage area..ARTCC FREQUENCIES
Old 09-07-2009, 05:51 PM
FLRAILMAN's Avatar
Default ARTCC freqs.
Also try this site, the webmaster keeps the sector frequencies pretty much up to date. On the upper left corner, click on: Aviation-then-Aviation monitoring-then-ARTCC centers.
Freq Of Nature
FLRAILMAN
Old 09-11-2009, 02:00 PM
I'm not sure if we are talking about the same thing here but I'll give it a shot.
I have frequencies programmed into my scanner for the Albany, NY area. When the ARTCC frequencies come in, it is only the aircraft talking to the center but NOT the center talking to the aircraft.
Is there any way to listen to what the center is saying to the aircraft or am I just too far away from the center to hear these transmissions? Are they on a separate frequency than what the aircraft uses to talk to the center?
Thank you!
Old 09-12-2009, 08:18 PM
FLRAILMAN's Avatar
Default ARTCC comms.
If you are in close proximity to an ARTCCs RCO (Remote communications outlet) you will hear the controllers directly, if not, don't worry because the aircraft repeat what the controllers say anyway.
FLRAILMAN
Old 09-15-2009, 07:18 PM
thenewsden's Avatar
FLRAILMAN
Is there somewhere to find the actual location of the ARTCC's RCO?
-Lee
Old 09-15-2009, 10:07 PM
rmiller818's Avatar
Some are depicted on en-route charts.
There are also lists on here that list a general location of sites, near towns, mountains etc.
Old 09-16-2009, 04:10 PM
FLRAILMAN's Avatar
Default ARTCC RCO freq's PA to TN via I-81
I have one more ARTCC frequency chart besides the two Bucko & I gave you earlier: Military Comms Monitoring. HF VHF UHF just click on ARTCC Center Freqs. on the left side of the home page so now you have three ARTCC charts to work with. You will be traveling through the following ARTCCs on I-81 (KZNY) New York Center, (KZDC) Washington Center, & (KZTL) Atlanta Center, this is presuming that your trip ends where I-81 ends in Jefferson County Tennessee & not further west toward (KZME) Memphis Center. I included a town & city finder website that covers each state you will be traveling through so you can match any locations on the list that match the specific ARTCC RCO charts locations. Good luck.
FLRAILMAN
Towns in USA, States, List of Counties, Points of Interest, Businesses, Lodging, History, News, Real Estate, Tourism
Old 09-16-2009, 04:55 PM
thenewsden's Avatar
I understand that there are lists that contain names that sometimes give clues as to where the transmitter is located. I was hoping to get a little more specific, such as coordinates or something. That way I would be able to narrow down a little better how my reception is based on where the transmitter I am hearing is located. Thanks again for all of your help and comments on this.
-Lee
Old 09-16-2009, 05:53 PM
crayon's Avatar
RF Cartography Ninja
Send a message via ICQ to crayon Send a message via MSN to crayon Send a message via Yahoo to crayon
RCO's do not service ARTCC's. That would be an RCAG.
Outlets are also given different names according to the type of facility they serve. If an outlet serves an AFSS/FSS, it is called a RCO. If an outlet serves a terminal facility (control tower or approach control ), it is called a Remote Transmitter/Receiver (RTR). If an outlet serves an Air Route Traffic Control Center (ARTCC), it is called a Remote Communications Air/Ground (RCAG) facility. GCOs can serve any type of facility, in fact they often serve two facilities simultaneously according to the number of clicks keyed on the microphone.
FAI AFSS - Overview of Services
Hermetically sealed to protect against moisture.
Old 09-16-2009, 06:15 PM
FLRAILMAN's Avatar
Default ARTCC RCO coordinates
I called the FAA & they said that there is a CD that they have available that should fit your needs, I hope you are taking a laptop. Here goes:
FAA Charting Office
Aeronautical information Services Division
1-866-295-8236 EXT: 35442
ARTCC Facilities & Frequency CD
They said if you need it immediately it might be available at:
Albany County Airport Authority
Million Air Albany
Albany Airport
518-242-2226
FLRAILMAN
(PS) Crayon is right the ARTCCs remote outlets are called (RCAGs) sorry about that.
Similar Threads
Philadelphia Taxi Frequencies Septa3371CSX1 Pennsylvania Radio Discussion Forum 4 07-18-2008 08:48 AM
Bossier Parish SO frequencies..... ka5lqj Louisiana Radio Discussion Forum 3 03-12-2008 06:48 PM
Pilgrim's Pride Corporation frequencies NEEDED rcmodelr Alabama Radio Discussion Forum 8 03-09-2008 11:27 PM
Mapping Frequency Location Dave_D General Scanning Forum 14 08-01-2006 10:33 PM
