Go Back   The RadioReference.com Forums > Topic Specific Forums > Aircraft Monitoring Forum
Aircraft Monitoring Forum This is the place to discuss monitoring aircraft communications, including ACARS digital transmissions.
Old 06-09-2005, 10:42 PM
ocandstiggs1968's Avatar
Default help for sawyer air base in northern michigan
hey i live at sawyer air base which is now closed in northern michigan but still has plenty of military flights comeing and going i should know i work right next to the flight line at a lumber yard but any way when i search on milair and other websites i cant find the right frequincies is any body out there monitering this area and can you help me i see lots of c130s and kc135s and some fighters but cant hear them whats up????????........................................ .................please help a thought or opinion perhaps
Old 06-09-2005, 11:42 PM
experimental_pilot's Avatar
Someone at MilAirComms chat will be able to help you.
You cant get anything for nothing, in aviation.
http://img.photobucket.com/albums/v6...aturefinal.jpg
Old 06-10-2005, 08:05 PM
Chief71's Avatar
Default Re: help for sawyer air base in northern michigan
ocandstiggs1968,
Check my post in the MICH Scanning forum I've got a lot of freqs for aircraft from Selfridge ANGB, hopefully that will help you.
Old 06-17-2005, 11:04 PM
Garymaxon1234's Avatar
Hi ocandstiggs1968
I found these at: http://www.fltplan.com/ type in SAW in the quick airport window.
SAWYER Tower Frequencies: 119.975 MHz Hours (local) of operation: 0600-2200
SAWYER Ground Frequencies: 121.65 MHz
Unicom Frequency: 122.700 MHz
AWOS: 118.37 MHz
APCH/DEP SERVICE PROVIDED BY MINNEAPOLIS ARTCC ON FREQS 119.1/290.2 (SAWYER RCAG).
I was stationed there in the mid 70s. I have an old frequency card but it doesn’t have any description of what the frequency was used for. Some of the UHF frequencies we used were: 289.0, 275.8, 255.6, 259.3, 269.0, 236.6, 257.8, 364.2, 344.6, 395.9, 290.9, 388.2, 391.9 and 255.4 MHz. I think the first was our squadron ops, the next 4 or 5 may have been used by the tower, and the last one. I’m not sure about the others, I’ve slept since then. Does bring back some memories of the UP though.
GM
Old 06-17-2005, 11:05 PM
Hi ocandstiggs1968
AWOS: 118.37 MHz
GM
Old 06-18-2005, 08:56 AM
MacombMonitor's Avatar
Take a look here:
http://www.milaircomms.com/artcc_zmp.html
MacombMonitor
Old 06-19-2005, 10:22 PM
poltergeisty's Avatar
Speaking of Sawyer air base. Check this out.
http://www.holology.com/haarp.html
Heres the reason why I say this.
From the site.
HAARP is officially claimed to be an ELF radio research project. ELF radio has an interesting history and some useful attributes that give it military value. Project Sanguine by the US Navy once used ELF radiation in the 40-80hz range to test communications capabilities. Evidently these tests were successful because they later upgraded the 45 km (yes that's kilometers) Project Seafarer antenna an Clam Lake Wisconsin with a 222 km one. Another 90 km antenna was constructed at KI Sawyer Air Force Base in Michigan. Navy ELF radio is primarily a very simple one or two letter signal used for granting the 'go-code' to pre-positioned subs to launch their nuclear missiles. Alternatively because of the limitations of this communications system ELF is used as a "bell ringer" to notify the submarine crew to surface and use more conventional radio. Boo!-Poltergeisty :-0
Sense when did Congress take the Hippocratic oath?
