I was going to say that you must have been near SLC. That is the only airport in the nation I have flown into that uses that phraseology. If you can get a copy of the SIDs/STARs used at SLC, most of them (if not all) have multiple crossing restrictions that have either an altitude restriction (at xx ft, at or below xx, or at or above xx), a speed restriction (usually at xxx kts) or both. When there is no need to slow an aircraft down to the published speeds, or have them fly faster than they typically would to comply with the restrictions, ATC will issue that clearance.
Craig Mills
Denver, CO
MNN //113//
