Airbender, as everyone said before, with aviation, height is the key! You want to get the antenna as high as you possibly can. Aviation radios run at a low power.
As said before, the airport is the hardest thing to get, next to the ARTCC's.
I have been thinking of making a 1/4 Ground Plane cut for the airband range, and another cut for the Milair band. I will let everyone know how that works too
But for now, I would reccomend a discone. The Diamond D-130 should do the job. Also, run by the Home Depot and get a amp for it too. That helps tremendously for me, a RCAG is right near me, but most of the planes are very far. The mountains don't help either
I have 50' of RG-6 with the F-BNC connector + a 12db premap. Works great. I have logged planes south of Atlanta, and north of Knoxville, TN. About 150+ nm
Anyway, go with a discone, or the Antennacraft ST-2. Those are a great starter antennas.
Good luck!
Caleb
