novascotian
When in a list of ARTCC freqs some are listed as discrete, what does that mean. For example high discrete....
is it saying these are overflow frequencies that some are sent to when it is too busy on the regular ones
I'll take a swag and say that it means that it is the only frequency assigned to the sector.
I would take that to mean that a 'discrete freq' is an 'overflow freq'.
I think they simply mean its a temporarily assigned channel between the pilot and atc.
What this means for practical purposes is, a controller will put you on a less populated frequency if he needs to give special instructions to keep the main frequency for an area open.
That is what it sounds like the FAA definition means. However the frequencies that the FAA list as discrete are not being used this way, a lot of the listed discrete frequencies are clearly the primary frequency being used in the sector. So I still don't understand what criteria the FAA uses for making the distinction ?
Discrete may mean "do not use this for special use, this is the designated frequency for this area", and non-discrete frequencies are available for spillover or special use.
that reason that I've personally seen used by a controller when I was talking to him, I dunno
The faa prob. Doesnt care how they are listed...
Any chance you remember what area/sector/frequency that was ? large low sectors often use multiple frequencies so it's not uncommon to be switched to a different frequency being used by the same controller
Memphis center in central AR
