| Aircraft Monitoring Forum This is the place to discuss monitoring civilian aircraft communications, including ACARS digital transmissions. |
02-19-2013, 12:24 AM
92-9000 VC-25A 747 Air Force One with Full ADS-B Transponder
One of the famous aircraft started using ADS-B transponder
The 92-9000 747 (AF1) aircraft with full ADS-B.
Aircraft: Boeing VC-25A (B742)
ModeS: ADFDF9
92-9000 Screenshots ADS-B Tracking Photos:
http://forum.flightradar24.com/threa...e-One-18-02-13
Showing 3 saved flights from Feb 14, 15, 18, 2013
Watch the Play-Back on this page.
http://www.flightradar24.com/data/airplanes/92-9000
If this aircraft keep using Full ADS-B.
It will be available on sites like PlaneFinder.net , FlightRadar24.com , PlanePlotter software, etc...
02-25-2013, 11:38 PM
Re: 92-9000 VC-25A 747 Air Force One with Full ADS-B Transponder
ModeS: ADFDF9
nice find. surprising, but nice
02-26-2013, 3:51 PM
I am really surprised that AF 1 allows itself to be tracked like that.
Shadcall
Pro 106 Pro 163 Pro 164
02-26-2013, 6:15 PM
It probably was not on an AF1 mission at the time.
David T. Stark
NF2G WQMY980 KYR7128
02-26-2013, 10:41 PM
why would it have the AF1 call sign if it wasn't?
02-27-2013, 7:03 AM
You need to read up on how those aircraft are used and the security precautions that are taken routinely to protect the location of the President and his aircraft in transit.
I have seen two aircraft simultaneously using AF1 on Mode-S. This is not unusual, especially during overseas trips.
David T. Stark
02-27-2013, 2:48 PM
I'm quite aware of the precautions. I've been part of details protecting it (on the ground at least).
But since it departed FL for DC, I wouldn't really consider that an overseas flight
02-28-2013, 5:39 AM
I've seen it happen between Andrews and NYC. YMMV.
David T. Stark
03-24-2013, 6:44 AM
HP-1|PSR-800|BC780XLT|Pro-92
PlanePlotter Ground Station ya
04-03-2013, 8:48 PM
AF1 recently arrived in the SF Bay Area (today).
NO ADS-B was noted but I was able to get MLAT fix on it though.
Interesting, it was not transmitting the "AF1" callsign through MODE-S like it normally does. I almost missed it because I flag "AF1" as an alert instead of the registration 92-9000. Guess I need to set up alerts for both.
04-07-2013, 9:19 AM
I've track AF1 in Mode-S only, no ADS-B while tracking them on VHF with Boston Ctr. With that said, I've seen snapshots from Europe showing full ADS-B datablocks.
04-07-2013, 5:55 PM
AF1 has recently only started showing on FR24, its a regular on PP (planeplotter) via MLAT but as they have the power and means on the sam flight it can show as any aircraft it wants with obama onboard, good when you get it aswell with the comms, nrmally shows and heard as SAM... over the uk doesn't use the AIRFORCE1 callsign much
