Go Back   The RadioReference.com Forums > Topic Specific Forums > Aircraft Monitoring Forum
Aircraft Monitoring Forum This is the place to discuss monitoring civilian aircraft communications, including ACARS digital transmissions.
Old 02-22-2013, 12:54 PM
safetyobc's Avatar
Forums Moderator
Send a message via Yahoo to safetyobc
Default What does this mean?
When listening to aircraft, I hear, "3-5-0 cactus 1773"
3-5-0 is the altitude. 1773 is the flight number. What is Cactus? I also hear "Sawmill"
Is that an airspace or frequency? If airspace is there a map that shows them?
Thanks for any info
Old 02-22-2013, 1:01 PM
ChrisP's Avatar
In this case, CACTUS is the company call sign for US Airways commercial flights. You heard US Airways flight 1773.
CACTUS came from the old America West airline, who used CACTUS as their company call sign, and when US Airways merged, they continued to use the CACTUS call, I believe because the pilots operated under the original America West union contract...
- Chris
Chris Parris
Fed Files Columnist
Monitoring Times Magazine
chrisparris@monitoringtimes.com
http://www.monitoringtimes.com
http://mt-fedfiles.blogspot.com/
Old 02-22-2013, 1:06 PM
safetyobc's Avatar
Forums Moderator
Thanks. Any idea who Sawmill would be? They will say "request permission to go direct Sawmill"
Old 02-22-2013, 1:14 PM
ChrisP's Avatar
"Direct SAWMILL" indicates that SAWMILL is a waypoint that the aircraft is headed towards. They were cleared to head directly to SAWMILL rather than go through other waypoints on their original flight plan. You can search around on the Internet for waypoint names, but I don't have a link in front of me now. Maybe some of the aviation monitoring buffs can help...
The more you listen to aviation communications, the more you will pick up along the way.
- Chris
Chris Parris
Fed Files Columnist
Old 02-22-2013, 1:16 PM
safetyobc's Avatar
Forums Moderator
I appreciate the information!
Old 02-22-2013, 3:58 PM
Nice replies ChrisP!
Sorry to nitpick but Sawmill(SWB) is a VOR in the area of Winnfield, Louisianna.
Therefore ATC instructed Cactus 1773 direct to the Sawmill VOR.
I believe waypoints are made of 5 letters
ex. There is an approach sequence into KMCI (Kansas City) that uses the following points
"SPICY" "BARBQ" "RIBBS"
Old 02-22-2013, 4:16 PM
ChrisP's Avatar
No problem. I didn't know specifically if SAWMILL was an intersection or a VOR or what. I knew there was a limit to the length of the names, but they do a lot of abbreviating, such as SAWML or BLAZR.
One thing about aviation communications is that there is a lot of "shorthand" used, so listening and learning takes some time.
Chris Parris
Fed Files Columnist
Jay911's Avatar
Send a message via Skype™ to Jay911
As for the first part which I think has been yet unanswered, the most likely response is that the pilot was acknowledging a direction for either flight level 350 (35,000 ft) or heading 350 (10 degrees left of due north). It's common practice in aviation communications to reply to an instruction by reading it back. So:
Call from controller: "Cactus 1773, Little Rock Center, descend to flight level 350."
Response indicating acknowledgement and compliance: "350 for Cactus 1773."
Old 02-22-2013, 4:18 PM
safetyobc's Avatar
Forums Moderator
Is there a map of these VOR's?
Old 02-22-2013, 4:24 PM
You can look up navaids and fixes on AirNav
There are a few google earth files of navaids and fixes. I'll post a link if I can find it.
Tom
Old 02-22-2013, 4:30 PM
safetyobc's Avatar
Forums Moderator
This site is great for looking them up. Thanks for all the info!
Old 02-22-2013, 4:31 PM
Jay911's Avatar
I gather AirNav is only good for USA .. it couldn't find my local intersections. SkyVector did, though. (ALBRO is almost directly over my house - only about 500 ft east of me!)
Old 02-22-2013, 4:44 PM
Great references above.
Here's a favorite of mine,
linked to KMSY (Louis Armstrong Airport in New Orleans) for the O.P.'er
make sure you "tick" navaids for the VOR's and Beacons(NDB) to show.
Louis Armstrong New Orleans International Airport @ OurAirports
Old 02-23-2013, 6:38 AM
DaveNF2G's Avatar
Airnav only works for USA facilities. Worldwide facilities (including USA) can be found on the Great Circle Search site -
Great Circle Search
Another cute approach is ITAWT-ITAWA-PUDDY-TAT.
Instructions to particular headings are rare except when approaching an airport. Most directional clearances involve waypoints or VORs. If you hear numbers, they probably refer to altitudes.
David T. Stark
NF2G WQMY980 KYR7128
Old 02-23-2013, 3:41 PM
JoeyC's Avatar
An intersection is typically a 5 letter "word" such as your examples.
An intersection or a VOR or any nav aid or aviation fix can be a waypoint.
Old 02-23-2013, 4:13 PM
Thank you JoeyC, appreciate your explaination.
Old 02-23-2013, 8:24 PM
737mech's Avatar
If the comm was descend to flight level 350 you'd probably be monitoring a high altitude atc center freq. The comms can be so fast you might miss something. Heading 350 could be any atc approach or departure or tower etc. Most airlines cruise at 35000 to 42000. LA Center for example would probably give a "Descend to FL350" When they are way up there the up and down adjustments are for better rides due to turbulence or for spacing when other aircraft are near. The only time I ever heard descend to FL450 was a U2 coming down from a mission. That NASA WB-57 goes up pretty high also, sometimes flightaware shows them at FL600.
In Omnia Paratus!!
BCT-15 / BCT-15X / PSR500 / PRO2051/ BC125AT
Old 03-08-2013, 7:35 AM
poltergeisty's Avatar
Location: RLG, Fly heading 053, intercept 315 DVV, look for the SAM
Send a message via ICQ to poltergeisty
That's funny. It's like over Vegas they have POKER, CHIPS and LUXOR.
The US of A, the most powerful military in the world.
Loneliness and the feeling of being unwanted is the most terrible poverty.
-Mother Teresa
http://www.youtube.com/watch?v=88ikSlFfW9M
Old 03-08-2013, 9:37 AM
My airport (Millville NJ, KMIV) uses the term lattie. As in "in bound lattie for runway 24." Cannot find any reference on the sector maps for lattie. Any ideas what this term means?
Old 03-08-2013, 3:29 PM
ChrisP's Avatar
LADIE is the outer marker for runway 10 at MIV. You can look here on the approach plate:
http://155.178.201.160/d-tpp/1303/00891IL10.PDF
BTW, MIV doesn't have a runway 24. It could be they were inbound to runway 14, they could call inbound at LADIE and then do a visual approach to 14.
- Chris
Chris Parris
Fed Files Columnist
