Houston Center Frequency
pinkfish457
Slidell, Louisiana
I am using SDR# to monitor local aircraft frequencies and found 132.175 FM, from Houston Center. I've been monitoring it for several days, and have confirmed it is from Houston Center. I am guessing it is Lacombe, Louisiana as I live about 15 miles away.
pinkfish457
AirScan
found 132.175 ... I've been monitoring it for several days, and have confirmed it is from Houston Center. I am guessing it is Lacombe, Louisiana as I live about 15 miles away.
According to the RR and FAA database's the 132.175 transmitter is located at Grand Isle, around 80 miles south of Lacombe. However when you look at the coordinates provided for Grand Isle on Google Earth there does not appear to be an antenna tower (RCAG) at that location ? So maybe 132.175 has been relocated to Lacombe ?
When you say you are hearing traffic on 132.175 I presume you mean the controller, or just aircraft ? How strong can you hear the controller ?
I'm curious if you can hear the controller on any of the other Houston frequencies that are listed at Grand Isle and Lacombe ?
Grand Isle site
132.650
135.775
134.900
Lacombe site
126.350
126.875
127.000
Any reception reports on the above frequencies appreciated.
pinkfish457
Slidell, Louisiana
Houston Ctr Frequency
Grand Isle site
132.650
135.775
134.900
Lacombe site
126.350
126.875
127.000
I'm receiving both controller and aircraft loud & clear. I have a multiband antenna on the roof of my house. I live too far from Grand Isle, I'm sure it's not that location. I haven't tried the other freqs, as soon as I do I'll repost.
pinkfish457
AirScan
pinkfish547,
Sounds like a nice setup.
If it's any help I've attached a copy of a chart I put together showing the high altitude sectors in that area. If you happen to notice any errors or changes and it's not to much trouble can you let me know. Thanks.
nd5y
Wichita Falls, TX
FAA location data is often way off. The Grand Isle RCAG appears to be at 29.224, -90.02 in real life.
AirScan
Yes the FAA info. is not always accurate, I looked around the general area but didn't see it. Thanks for that, it does look like a typical RCAG.
