novascotian
This has likely been discussed many times but I have never seen a clear answer. VHF aero is what I like best in the scanning hobby and I have tried many different scanners. In the last ten years or so most of what I have bought have been trunking scanners of various types so I can listen to everything else too. Trouble is that none of them have done well at all on VHF aero, so that I continue to rely on my old Uniden BC590 XLT which is a simple VHF and 400 MHz scanner with no computer programming or alphatags. It does a great job, head and shoulders above everything else. I have or have had the following: PSR 400, BC 396 XT, 996, PRO 95, PRO 97, PRO 99, PRO106.... plus some others earlier. Yep, some of them are handhelds.... but the point is none were good on vhf aero... I just got the PSR400 and it like the others doesnt pick up my local ATIS and really only gets the strongest of the local airborne traffic, while the 590 will be hearing the ATIS and the tower, ground controller, area controller very well. So let's hear it.... what have you found to be good, and I am looking for comments based on comparing with something else using the same antenna and location.. ??
