moonbounce
- Joined
- Nov 5, 2002
- Messages
- 1,404
I am using SDR Sharp veraion 1357 to listen to the air band. I find that to listen to the air band I have to have the squelch at a decent level otherwise I don't pickup much. but the problem with the squelch closed to much is that it produces a lot of hiss. If I turn the squelch to a more open position I lose signals.
So the simple solution seemed to be to use the mute button to cut out the noise, but when the mute button is activated and I start scan I get an error message and SDR Sharp won't scan. The error message says "Value 15 is not valid for Value. Value should be between Minimum and Maximum" . So I tried adjusting everything with a minimum and maximum value but when I start scanning the error message is back. The only way to continue scanning is to unmute.
Moonbounce
Moonbounce
