I am trying to figure this out. I found a shortwave database listing. I can go through each freq one
at a time and it tunes the radio perfectly but can't scan. There is another feature in Ham Radio Deluxe
that allows for scanning. However I can't import this database into the area for scanning.
For scanning it offers 2 areas. You can scan individual freqs with the "Fravorites" that are included and consist of Ham Radio Freqs, by choosing
them one at a time getting placed into a list to be scanned. The other choice is any freq on
the display can be added to the list. This is a little better than typing in each freq but this a pain.
Once the scanning list is created and saved you can recall it for scanning. I found where
in HRD the list is saved. I made up a short list of freqs for a test and saved it.
I am thinking this might be the format to use for scanning if the file you mentioned could be
converted into this format which looks basic.
I will email you both the shortwave database which is fine if I want to tune into each freq by clicking
it. I will also email you the the short list which does scan.
Ken
Give me the format that HRD uses for its data files and I'll try to make a file to suit. I'll need to know the headings and file type and probably I won't be able to test it as I don't use HRD so it could be buggy for the first try! Attached is a tab delimited text file of the MWARA frequencies from last year - just see if that works.
