Go Back   The RadioReference.com Forums > Service Specific Monitoring > Aircraft Monitoring Forum
Aircraft Monitoring Forum - This is the place to discuss monitoring civilian aircraft communications.
Old 09-13-2018, 11:31 PM
mike619's Avatar
Default Aviation scanning question
I was wondering what is the most effective way to get the most out of aviation scanning with certain scanner setup i.e
Bank 1 or quick key 1 Towers
Bank 2 or quick key 2 Tracon
Bank 3 or quick key 3 ZLA ARTCC
Bank 4 or quick key 4 Air to Air
Bank 5 or quick key 5 Airline company
Monitoring Milair and fire radio.
BCD396XT BC246T PRO-96 PRO-83 PRO-36-for some uses
Old 09-14-2018, 2:13 AM
pinballwiz86's Avatar
There is no need for all that segmentation. All you are doing is using up 5 banks that could be all put in 1-2 banks.
This is assuming you at least have a scanner that can do 100 channels/second.
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 09-14-2018, 2:48 PM
your biggest improvement would be an exterior antenna and low loss coax and dont use so many banks...take time to listen to the most active freq.
scanning the pinelands of south jersey bcd436hp pro651 pro652 pro2006 pro2096 bct15 grundig satellit 800
Old 09-14-2018, 4:12 PM
I have been monitoring aviation for years and I have a similar setup. I live near the world's busiest airport, so there are many active frequencies. I find if I just scan "everything" then the scanner stops and stays on Approach or Atlanta Center because they are so busy. I find making banks of certain types of air band frequencies helps. This way I can fine tune what I want to listen to.
Here is my setup:
0 - Mil-Air
1 - Approach/Departure
2 - Ground Ops, ATIS
3 - Towers
4 - Airport ground ops.. catering, shuttles etc.
5 - Maintenance, Airinc, Dispatchers, FBO's,
6 - Distant Center and Approach freq's
7 - General Aviation, unicoms
8 - ATL Center
Day to day scanning I will monitor banks 2, 3, 5, and 7. When weather is in the area I will listen to approach and center to listen for the holding patterns, diversions and the always fun "going around".
BCD396XT, BCD325P2, BC95XLT, ICOM 880H, Yaesu FT-857D
Old 09-14-2018, 5:45 PM
Default I use multiple banks too :)
I second SkiBob's post. I have been monitoring Civilian and MilAir for many years. It's my favorite monitoring. I always use separate banks. I have separate banks for the following:
Colorado Springs Airport
Butts Army field
Air Force Academy field
Denver Center
Denver International Airport
etc, etc....
