I don't know what is currently in use by FEMA in Alabama, but I would definitely search the 406-420 MHz federal band for FEMA activity.
There might also be National Guard and some FEMA activity in the 138-144 and 148-150 MHz bands, and check the 30-88 MHz low-band for National Guard activity.
Give this list a try it may be good or may not http://www.radioreference.com/downloads/pdf/64577-agency-1049.pdf
Some reason for me it opens and shows bottom blank area of page but scroll up for data. If link does not work go to Alabama page in database and use dropdown in Alabama State Agencies.
While FEMA does have radio equipment in some of their vehicles, the personnel that I have seen in recent weeks are using satellite phones. This is usually done when the communications infrastructure in their response area is torn down - as it is in the northern half of Alabama.
Most of the FEMA personnel that I see in Alabama are using the same Southern LINC PTT phones that Alabama EMA uses on the Southern LINC system. Unfortunately, you can not scan this system.
