post file here if ya can .. rename it xxxx.txt also ya can send to puzzle (DOT) ridddle at yahoo (DOT) com and will take a look at it. mean while make sure ya have ALL the frequencies & NOTjust the control channels oops I Isee rwier's file will look at it also.. hmm Which antenna are you using. Th RS 800mhz is highly recommended by most.
Update:
I feel like a total idiot but it's all part of the learning and experimentation process. I was watching the scanner scan for a bit via win500's virtual scanner when I noticed a "mute" button highlighted. I did a bit of googling and found out how to switch modes (probably not the correct term).
Anyhow I pressed the attenuation button and BAM, stolen Cadillac in downtown Bham
I also experimented a bit with assigning certain freqs to scan groups, so now I see why you don't group them all in the same one. I have the N,E,S,W Precincts grouped in a scan group and the other misc. freqs in another.
Here's my next goal:
Reception was phenomenal at about midnight, great weather, sitting outside but I lost quite a big of signal being indoors. I'd like to buy a beefier antenna for the pro-106 and would love to hear some recommendations. Should I buy one that mounts on the unit, maybe one that mounts outside my bedroom's window? Perhaps both? I'd also like one on the roof of my car, but that's secondary to home listening.
Great forum here!
