Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Alabama Radio Discussion Forum
Alabama Radio Discussion Forum Forum for discussing Radio Information for the State of Alabama.
  #101 (permalink)
Old 12-12-2012, 9:35 PM
N8OAY's Avatar
I confirmed a bunch of talk groups today, and found a few new ones. The 306## series is Madison County Fire. I confirmed the encrypted talk groups by matching up Radio IDs that had affiliated with previously confirmed talk groups. So far, it looks like Bobo, Harvest, Meridianville and Monrovia VFDs are the only County Fire Departments that have the new radios.
On some calls this week, Madison County Fire Dispatch is using the P25 system, and some calls are the VHF 154.385 patched into the P25 system. If you listen to 154.385, it is obvious which radios they are using (the audio is considerably lower when they are on the P25 radios). All of the calls on the P25 system are patched into the VHF, and all VHF calls are patched into the P25 system. There is a lot of activity on other talk groups that is not being patched into the VHF frequencies. I am guessing that the patches will stop and everyone will be on the P25 system by January 1 so that they do not have to pay for narrow banding the VHF system. Likewise HEMSI.
I am thinking the 30000 through 30005 will be County Wide Common talk groups. I have seen Radio IDs that have been affiliated with HPD, MCSO and County Fire on 30000 and 30001. One new frequency was added to the Huntsville P25 towers today - 857.66875.
3 Huntsville PD Dispatch North
5 Huntsville PD Dispatch South
7 Huntsville PD Dispatch West
11 Huntsville PD (Encrypted)
125 Unknown
215 Unknown
455 TECH 1
800 Unknown
6412 Unknown
30000 Common?
30001 Common?
30002 Common?
30003 Common?
30004 Common?
30005 Common?
30025 Huntsville PD (Encrypted)
30026 Huntsville PD (Encrypted)
30028 Huntsville PD (Encrypted)
30029 HPD (Encrypted)
30030 HPD (Encrypted)
30031 HPD?
30032 HPD (Encrypted)
30034 HPD (Encrypted)
30035 HPD? (Encrypted)
30036 HPD (Encrypted)
30039 HPD (Encrypted)
30044 HPD (Encrypted)
30045 HPD (Encrypted)
30046 HPD (Encrypted)
30047 HPD?
30048 HPD?
30225 MCSO Dispatch
30226 MCSO (Encrypted)
30227 MCSO (Encrypted(
30228 MCSO (Encrypted)
30229 MCSO (Encrypted)
30230 MCSO (Encrypted)
30231 MCSO?
30235 MCSO?
30236 MCSO?
30237 MCSO?
30238 MCSO?
30239 MCSO (Encrypted)
30240 MCSO
30242 MCSO?
30243 MCSO?
30244 MCSO
30525 HEMSI Dispatch "Med Com"
30526 HEMSI Ops 1
30527 HEMSI
30528 HEMSI
30529 HEMSI Paramedics to Hospitals (Encrypted)
30530 HEMSI?
30531 HEMSI?
30532 HEMSI
30533 HEMSI?
30534 HEMSI?
30535 HEMSI?
30536 HEMSI?
30537 HEMSI?
30538 HEMSI?
30539 HEMSI Supervisors
30540 HEMSI
30541 HEMSI
30542 HEMSI?
30543 HEMSI?
30544 HEMSI?
30625 Madison County Fire (Encrypted)
30626 Madison County Fire (Encrypted)
30627 Madison County Fire Ops 1 (Encrypted)
30628 Madison County Fire (Encrypted)
30629 Unknown
30630 Madison County Fire (Encrypted)
30631 Unknown
30632 Unknown
30633 Unknown
30634 Madison County Fire (Encrypted)
30635 Madison County Fire (Encrypted)
30636 Madison County Fire (Encrypted)
30637 Unknown
30638 Unknown
30639 Madison County Fire (Encrypted)
30640 Unknown
30641 Unknown
30642 Madison County Fire (Encrypted)
30643 Unknown
30644 Madison County Fire (Encrypted)
30645 Unknown
30646 Madison County Fire (Encrypted)
30647 Unknown
30648 Madison County Fire (Encrypted)
30650 Madison County Fire (Encrypted)
30652 Madison County Fire (Encrypted)
30653 Unknown
30654 Madison County Fire (Encrypted)
30655 Unknown
30656 Madison County Fire (Encrypted)
30657 Unknown (Encrypted)
30658 Unknown (Encrypted)
30659 Unknown
30660 Madison County Fire (Encrypted)
30661 Madison County Fire (Encrypted)
30662 Unknown
30663 Unknown
30664 Unknown
30665 Unknown
30666 Madison County Fire (Encrypted)
30667 Unknown
30668 Unknown
30669 Unknown
30673 Madison County Fire (Encrypted)
30674 Unknown
30927 Unknown (Encrypted)
Dave Marshall N8OAY
http://www.aosc.org
PSR-500, PRO-96, BC780XLT, PRO-2067, PRO-2006/OptoScan 456, FT-90, VX7R
A former Ohio guy, now a Rookie Alabaman
  #102 (permalink)
Old 01-09-2013, 8:35 AM
N8OAY's Avatar
Pro96Com has detected 2 new frequencies:
769.33125
857.66875
Dave Marshall N8OAY
http://www.aosc.org
  #103 (permalink)
Old 01-09-2013, 9:12 AM
would i be correct to assume those are for the huntsville site?
also, do these have to be in any kind of logical order? i'm assuming no, since even without those programmed, the scanner still picks up traffic.
thank you
pro164
pro106
  #104 (permalink)
Old 01-09-2013, 12:54 PM
N8OAY's Avatar
Yes, these are both on the Huntsville towers. They do not need to be programmed. All you need is the control channels.
Dave Marshall N8OAY
http://www.aosc.org
  #105 (permalink)
Old 01-18-2013, 3:46 AM
N8OAY's Avatar
If any of you can listen to the system Friday 1/18, it may be worthwhile. A new talk group #30125 showed up today with a considerable amount of what was probably radio tech activity. I am guessing it might be Madison Police, since it is between Huntsville Police and Madison County Sheriff. There were also several new 3 digit Radio IDs that showed up Thursday affiliated with 30125 including 3 dispatch consoles. There was also a lot of activity with the 16777215 "All Units - identifies all subscriber units" Radio ID.
Dave
Dave Marshall N8OAY
http://www.aosc.org
  #106 (permalink)
Old 01-18-2013, 11:09 PM
N8OAY's Avatar
Pro06Com found several new talk groups today in the 301## series, but no activity. All of the new talk groups show just one hit. Sometime next week, a new user will probably join this system.
Dave Marshall N8OAY
http://www.aosc.org
  #107 (permalink)
Old 01-24-2013, 12:05 PM
N_ALSCAN's Avatar
Talkgroup 215 is the Simulcast of the EMA EOC talkgroup
Rob
Huntsville, AL
  #108 (permalink)
Old 01-25-2013, 9:06 AM
heard some traffic today that sounds like huntsville fire will be the next to join
pro164
pro106
  #109 (permalink)
Old 01-25-2013, 1:42 PM
N8OAY's Avatar
There is no "will be" to it. As of a few minutes past noon, it sounds like they have vacated the old system. 301## series, so far all talk groups including 30125 Dispatch are encrypted.
I will post a complete list and all of the Pro96Com files later tonight.
Dave
Dave Marshall N8OAY
http://www.aosc.org
  #110 (permalink)
Old 01-25-2013, 11:18 PM
N8OAY's Avatar
OK, I'm not sure what is going on. HFD is back on the old system now.
Dave Marshall N8OAY
http://www.aosc.org
  #111 (permalink)
Old 02-21-2013, 10:38 PM
heard hfd moved ops to suppression today while the engines' radios were reprogrammed today. should be some new talk groups popping up soon.
pro164
pro106
  #112 (permalink)
Old 02-24-2013, 11:39 PM
huntsville fire is up and running on the digital system. main dispatch is not encrypted. talk group 30125.
pro164
pro106
  #113 (permalink)
Old 02-25-2013, 8:40 AM
N8OAY's Avatar
Madison County Fire is now showing up on Pro96Com as not being encrypted sometimes, and sometimes being encrypted. I'm not sure if that is an issue with either reception quality or if some radios have encryption turned off and others still have it turned on.
Huntsville Fire tactical talk groups are showing up with encryption being turned off.
Dave Marshall N8OAY
http://www.aosc.org
  #114 (permalink)
Old 02-25-2013, 9:19 PM
N8OAY's Avatar
I found 7 new frequencies today:
769.33125
851.71250
853.27500
853.66250
855.21250
856.43750
857.66875
Huntsville Fire is no longer using both systems. Talk groups for Huntsville Fire are:
30125 Huntsville Fire Dispatch
30126 HFD
30127 HFD TAC 3
30128 HFD TAC 4
30129 HFD TAC 5
30130 HFD TAC 6
30131 HFD
30132 HFD
30133 HFD
30134 HFD
30135 HFD
30137 HFD
30138 HFD
30139 HFD
30140 HFD
30141 HFD
30142 HFD
30143 HFD
30144 HFD
30147 HFD
30148 HFD
I assume there will be several more talk groups for HFD. They had 32 talk groups on the old system.
None of these talk groups showed as being encrypted in Pro96Com today, but I have seen them encrypted while HFD was simulcasting on the old and new systems.
Madison County Fire was showing not encrypted earlier today, but is back using encryption on everything tonight.
Pro96Com is now showing 6 Neighboring Sites (previously was just 303 and 304 which are New Market and Gurley sites).
303,"T0303",46b,"01-1596",771.98125,""
304,"T0304",46b,"01-1604",772.03125,""
307,"T0307",46b,"01-1320",770.25625,""
308,"T0308",46b,"01-1602",772.01875,""
309,"T0309",46b,"01-1918",773.99375,""
310,"T030A",46b,"01-1838",773.49375,""
I think 302 (the site I am logging) is the Monte Sano site. Two of these new sites should be Drake Mountain and Rainbow Mountain. I have no clue what the other two would be. According to what I am being told locally, the Madkin Mountain site that is on Redstone Arsenal is not going to be used for the new system.
Now I really need to figure out how to log some of these neighboring sites instead of just tower 302.
Dave Marshall N8OAY
http://www.aosc.org
  #115 (permalink)
Old 02-25-2013, 9:44 PM
thanks for all the info. when i was listening this morning, it seemed like a lot of traffic was missing. it would make sense if it was because it was on different sites. maybe one of them is on the tower county fire used as the ledges repeater? another could be on capshaw?
pro164
pro106
  #116 (permalink)
Old 02-25-2013, 10:15 PM
N8OAY's Avatar
I stand corrected on one comment in that last post...I just looked up the new call signs that show in the tower 302 file. The Madkin Mountain site is now included in the system. Neither of the FCC files for the new call signs shows an address for the 6th and 7th sites. I am guessing one of them might be in the far northwest near Harvest or Bobo, and maybe one will be far southeast near New Hope or the Huntsville Speedway, or maybe one of them might be near the new HFD Station 18 that is in Limestone County. Anyone else have guesses on this?
Dave Marshall N8OAY
http://www.aosc.org
  #117 (permalink)
Old 02-25-2013, 10:22 PM
N8OAY's Avatar
The Capshaw site certainly makes a lot of sense to me. I do not know where the Ledges site is. I doubt the Rainbow Mountain site can provide sufficient coverage all the way up to Bobo.
Regardless of which site you are closest to, you should be able to hear everything, since they are all networked together. I am seeing everything on the tower 302 site that I am able to log from home.
Dave Marshall N8OAY
http://www.aosc.org
  #118 (permalink)
Old 02-25-2013, 10:26 PM
oh ok thanks. the ledges site is on top of green mountain, i believe. it is the repeater new hope, owens crossroads and other eastern county vfd's would use back in the conventional days.
pro164
pro106
  #119 (permalink)
Old 02-25-2013, 10:56 PM
N8OAY's Avatar
I just got the address from the FCC license. I doubt that would work for the P25TRS. Google Earth shows the street address to be maybe a mile south of the WAFF tower which is on Rt 431. I am thinking it is too close to the Monte Sano site to be effective and would really need a tower further southeast in the county.
Dave Marshall N8OAY
http://www.aosc.org
  #120 (permalink)
Old 02-26-2013, 8:18 AM
morganAL's Avatar
Monte Sano, Drake, and Rainbow are a single simulcast cell which means all of the sites transmit the same site ID and etc. To radios and scanners, the 3 sites look like a single site.
