Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Alabama Radio Discussion Forum
Alabama Radio Discussion Forum Forum for discussing Radio Information for the State of Alabama.
Old 01-12-2013, 1:43 AM
Default Geneva County Alabama New Trunked System
Just found where Geneva County has a new Trunked Radio. What I thought was odd about it is that it is licensed under a rural vol fire dept. They can use up to 200 radios for the license. I'm not sure if it is active yet or not. The license allows for Digital Nexedge as well as narrowband.
WQPP657 (BELLWOOD VOLUNTEER FIRE DEPARTMENT) FCC Callsign Details
Icom V-8000, Icom ICR8500, Realistic Pro2006 x 2
Yaesu FT897D, GRE Super Amp 3001 x 2, AOR ARD25, Icom ID 880H D-Star,
Uniden Home Patrol-1, Uniden BCD996 T , Uniden BCD396XT
Old 01-12-2013, 1:45 AM
xxdanielt3's Avatar
That's odd its just for the FD. In the notes it says its to minimize property loss.
VOLUNTEER FD. TWO WAY RADIO DEVICES FOR TRANSMISSION OF COMMUNICATIONS ESSENTIAL TO PREVENT LOSS OF LIFE AND OR DESTRUCTION OF PROPERTY AND THE ENVIRONMENT.
RadioShack Pro-164 - Uniden BC95XLT - Motorola Minitor III - Kenwood TK-3302U - Baofeng UV5R - Minitor II - (2) Minitor V
Old 01-12-2013, 5:54 AM
Default emisione desgnator
includes 8K30F7W 12.5 kHz voice and data NXDN (IDAS, NEXEDGE)
Old 01-12-2013, 12:46 PM
Avery93's Avatar
It's possible the system was bought with a grant, and that department was the one that applied for it. Although if it was an AFG or SAFECOM grant, they should not have bought a NEXEDGE trunking system. Both of those grants now require the equipment purchased to be P25 CAI compliant, unless the applicant can justify why they think non-P25 gear aids interoperability.
The 12.5 KHz NXDN designator (8K30F1E) reveals that this is a Kenwood NEXEDGE system, as Icom only supports 6.25 KHz NXDN (4K00F1E). The NXDN trunking formats are also proprietary, so they will be locked in to using Kenwood gear.
