Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Alabama Radio Discussion Forum
Alabama Radio Discussion Forum Forum for discussing Radio Information for the State of Alabama.
Old 01-13-2013, 12:51 AM
Exclamation Unable to hear Hoover PD
Does anyone know if Hoover PD and FD have swithched to a new freq and if so what are they? I noticed that they have been modified on the database but the freqs look the same.
Old 01-13-2013, 7:28 AM
1 of 2 things or both.. they have narrowbanded therefore the power has been reduced ( may need a better anttenna) or the pls/dpls have changed. will listen out & report back.
Old 01-13-2013, 9:06 AM
Irishfireguy3622's Avatar
I noticed last Friday they had changed Dispatch, Tactical, Talk 1 and Talk 3 to a 131 DPL and submitted the info. No problems now.
Comm Gear: Motorola Spectras, XTS2500's, MTS2000's, HT1000, CM300, Yaesu FT8800 Dual band, RS Pro-2066
Old 01-14-2013, 1:01 AM
im using a home patrol and cant hear them
Old 01-14-2013, 2:32 PM
They are loud and clear on my PSR-800 in Rock Creek.
Support Improved EMS, More than just a ride to the hospital...The Ayatollah of Motorola hath spoken.
Old 01-14-2013, 8:51 PM
mike6454's Avatar
Smile Narrow Banding
How would i program 154.875 into my PSR-500 with narrowbanding?
Could someone please give me an example for this frequency?
All that Khz stuff to difficult to understand.
thank you.
Old 01-14-2013, 11:14 PM
Avery93's Avatar
I'm not very familiar with the HomePatrol, but if there is a way to manually edit channels, change the CTCSS/DCS to the new 131 DCS code. Or just download the newest database update.
thank you.
Not sure what this has to do with Hoover, but you would simply program it in as normal, and set the modulation to "NFM" instead of "FM". Narrowbanding does not change the center frequency, only the occupied bandwidth.
Old 01-15-2013, 12:26 AM
Cant say about PD but Hoover FD can be heard on 154.055
Old 01-15-2013, 7:13 AM
thank you.
program just like you typed here set it to NFM mode & add the pl tone
Old 01-27-2013, 4:03 PM
Default Hoove PD and Fire
I don't have my scanner handy right now -- back at my home in Ga.
I listened to PD and FD this week. As a previous post mentioned - they changed their squelch tone to one of the Digital Tones.
You'll be good to go.
Best Regards,
Julian780
Lagrange, GA
Old 01-27-2013, 4:20 PM
n5ims's Avatar
This shows one of the very good reasons to not program any tones for a scanner unless there are specific reasons to do so. Programming a tone into your scanner will restrict what you hear (you'll only get transmissions that match your settings) and increase the time the scanner takes to start sending the audio to the speaker (you may miss the first part of some transmissions). Unless you have interference from an unwanted system that makes it hard to pick up a wanted system it may be best to not program in the tone settings (you'll get everything on that frequency that way).
Other advantages are that some small agencies may have all normal traffic using one tone and a "special" channel programmed with a different tone so supervisors can talk without the others hearing them (yea, this is easy to defeat, but it's a cheap and easy way to get a new "channel" that isn't used much). Remember that most agency radios are programmed by the shop, and users can't make changes so something this easy to defeat may actually work for a small agency.
