Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Alabama Radio Discussion Forum
Alabama Radio Discussion Forum - Forum for discussing Radio Information for the State of Alabama.
Old 07-06-2018, 1:16 PM
Default Home Patrol 2 and Mobile, Alabama
I live near Mobile and thought the Home Patrol 2 was going to be the new great scanner. I am very disappointed in Uniden as it pick up very little. My cell phone free app at least will pick up most of the fire call but the scanner just sits. I feel i have it programmed correct and I even did the extreme upgrade and have tried multiple antennas still very little chatter on the scanner. I did put it in the truck and a few more conversations there but not even in Mobile county for the most part. Anyone around Mobile, AL know any local info.
Old 07-06-2018, 1:54 PM
Obvious question - have you updated the database? If so, range setting, and do you hae te needed service types on.
The extreme upgrade does nothing in changing reception or allowing one to hear more, it's mainly to allow some advanced analyses and keyboard entry of data.
According to this thread - a lot is encrytped.
I'd post in the AL forum for local help.
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
Old 07-06-2018, 1:58 PM
yes, I have done all of that.
Old 07-06-2018, 3:47 PM
hiegtx's Avatar
Mentor
You updated the database in Sentinel and also did a 'write to scanner' to update the HP-2 as well? In Sentinel, the database version's date is displayed in the lower left corner of the main Sentinel window. In the scanner itself, you can verify the version by pressing:
Menu to get to the Main Menu screen
At that screen, press Advanced Menu
On the Advanced Menu Screen, scroll down (use the down arrow to get to the next page) and press the Version Information option. That will show the database in the scanner, among other things.
If you are using the main database, and location, make sure that your location is correct in both the scanner and in Sentinel. If using a Favorites list, appended from the main database, the same caution on verifying location would apply if the list is set to use location. See How it Works: Location, Location, Location
Verify that all the public safety service types (Law, Fire, EMS, Multi) are enabled for Dispatch, Tac, and Talk.
Steve
SDS100-436HP (2)-536HP-TRX-1-325P2-among others
Old 07-06-2018, 4:04 PM
garys's Avatar
I'm not around Mobile currently, but you should make sure that the HP2 is monitoring the Mobile County P25 system, not the EDACS system. The DB here still shows the EDACS system as being the primary system for the county, but as far as I know, that system is turned off. At the least, all public safety have moved off of it.
Also, Mobile City Police and just about all of the other LE agencies are now encrypted, so you won't hear anything from them.
Old 07-06-2018, 5:05 PM
medic9351301's Avatar
What system are you using.
They have the county edacs
And the city p 25 system.
I don't live in mobile but I think the county edacs is the one you need .
https://www.radioreference.com/apps/db/?sid=374
Keep in mind all law enforcement is encrypted.
I would suggest the simulcast cast site.
That would probably give you everything county wide
Let's keep law dispatch channels clear .
As well as fire tacs clear.
I don't support encryption on dispatch channels.
medic9351301
Old 07-06-2018, 5:17 PM
Lets get user error out of the way before we blame the scanner.
Do you have the correct system or systems selected, did you do your homework and make sure local agencies arent encrypted, do you have the correct service types enabled?
Old 07-06-2018, 6:41 PM
wbswetnam's Avatar
He may also be experiencing simulcast issues.
Also, you don't live in a steel building, do you, BIGBOYal?
Too much of a good thing can be wonderful. - Mae West
Old 07-06-2018, 7:06 PM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
Threads merged. Please don't ask the same question in multiple threads. It makes it harder for people to help you.
Thanks.
Mike.
Old 07-07-2018, 11:28 AM
The simulcast distortion in Mobile is horrible. Unless you are very close to a site you probably will have a hard time hearing anything. I am in Mobile every week and have lots of issues with the simulcast distortion. Also, all city and county ps services are on the City of Mobile P25 system.
Old 07-07-2018, 11:42 AM
There is a stand alone site north of you between Turnerville and Lemoyne that might work for you (Salco Rd). Most, if not all LE is encrypted. The Salco Rd site will not have simulcast distortion if you can pick it up. .also, the system is Mobile county P25. I will submit a change from the old EDACS system to the Mobile P25 system.
Old 07-07-2018, 5:06 PM
garys's Avatar
Is the EDACS system in fact turned off?
Old 07-10-2018, 9:24 AM
No, I do not live in a steel building.
Old 07-15-2018, 12:32 PM
Checked out the Mobile county EDACS system this past week several days and yes it is still on and active. No LE or FD activity that I could determine , but still has "The WAVE" (Mobile transit), some road ops, some coal terminal ops, as well as some other unidentified use on it. I suppose it should be taken off the "deprecated" list on the database and put back on the Mobile county page under the Mobile county P25 system as still in use for services other than fire, ems, or law.
Old 07-15-2018, 12:35 PM
By the way, I'm not really sure what the comment about living in a steel building has to do with the original question of this thread. Just trying to give you some help with your original question but since you never did specify exactly what system you are trying to monitor I'll leave it to you.
Old 07-27-2018, 1:48 PM
I am trying to monitor fire, EMS, and Ambulance for City of Mobile and outlying Communities of Chickasaw, Saraland, and Satsuma.Thanks!
Old 07-29-2018, 10:52 AM
U will need to monitor this system for what u listed as your interest:
https://www.radioreference.com/apps/db/?sid=9284
However, I would suggest for your location that u monitor the Salco Rd site. The simulcast distortion in Mobile is terrible on site 4. Also, most LE is encrypted.
