Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Alaska Radio Discussion Forum
Alaska Radio Discussion Forum Forum for discussing Radio Information in the State of Alaska.
Old 07-31-2008, 12:04 PM
JerryNone's Avatar
Exclamation How does this work?
http://www.radioreference.com/apps/db/?sid=2447
One site has 800 Megacycles frequencies and all the other sites appear to have V.H.F. frequencies.
Wouldn't the users need to have two antennae? One optomized for 800 Megacycles and the other optomized for V.H.F.?
"Santa Must Be Polish" By Bobby Vinton.
Old 07-31-2008, 12:42 PM
daedalus's Avatar
I'm far from certain but the following quote from http://www.apco911.org/frequency/sie...nts/alaska.pdf may answer the question:
Deployable Systems
In support of widespread VHF use by responders in Alaska, both federal and state agencies are
employing VHF deployable trunk and conventional capabilities. These transportable systems
consisting of a base station and repeater equipment, trunked and conventional, will be staged at
central locations for response to emergencies. Conventional systems will use frequencies
adopted for nationwide interoperability (Appendix E). These conventional VHF frequencies are
programmed into the user radios to provide interoperability when beyond the coverage area of
the trunking system, both inside and outside of Alaska. These same transportable systems will
also maintain a cache of subscriber equipment to supplement deployed agencies that do not carry
P25/TIA-102A VHF trunked radio capabilities. Further, agencies operating 700 or 800 MHz
infrastructure are highly encouraged to maintain a cache of VHF P25/TIA-102A trunk radio
subscriber equipment to facilitate mutual aid and response outside of their home infrastructure
coverage. Alaska first responders who expect to engage operations outside of Alaska, such as
the fire service should then ensure that they have a communications capability compatible with
systems in other areas of the country.
Old 07-31-2008, 01:40 PM
n2mdk's Avatar
They would not only need 2 antennas but 2 radios as well.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 07-31-2008, 03:49 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
The local agency uses what band they need. It's all just audio paths within the system. It's much more simple than it looks.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Old 07-31-2008, 04:15 PM
Send a message via AIM to karldotcom
I am pretty sure Alaska uses HF regularly also.
Old 08-01-2008, 01:48 AM
Like Wayne mentioned, some agencies use 800MHz and the rest uses VHF. When a VHF user selects talkgroup A and an 800MHz user selects the same one, they talk seamlessly and the trunking sites take care of merging the two together. In the future they will add a bunch of simulcast nodes in the 700 MHz band, collectively known as 'AWARN', that will also interact with everybody on ALMR, virtually making it a 'tri-band' system.
JETorres
Similar Threads
ARC250 Settings for Conn. State Police - Will it work? OldHick Connecticut Radio Discussion Forum 5 03-01-2006 09:26 AM
Work for the Media Nwshnd Texas Radio Discussion Forum 5 02-03-2006 04:04 PM
The next step in 911 PSAPS, work at home n4voxgill Tavern Archives 12 08-29-2005 07:47 AM
will the pro96 work with the new rebanding plan mikeh Radio Shack Scanners 1 07-02-2005 05:21 PM
I can't get my 796D to work in Burlington County!! davesdaughter New Jersey Radio Discussion Forum 25 01-01-2005 05:50 PM
