Originally Posted by AK_Griz
1. In the extended trucking table, do I need to check one of the boxes under 9600 cc? I.E. VHF, UHF.
No, leave all unselected so it'll know to use the "custom" tables you put in.
2. The sound of people speaking on some of the MO channels sounds kind of like being in a tunnel/distorted and sometimes a squeaky squeal. Actually, it's the Alaska State Troopers cars and MAT-COM that sound that way. Any recommendations?
Sometimes it's that way due to many units not being in the system properly yet (i.e. patched from analog into ALMR) and it'll sound kind of weird when they're that way. You can hear a slight distortion and sometimes a little bit of a squelch tail and other 'sound artifacts' from the analog system if that's the case.
Other than that, no other ideas, they sound fairly good up here in FAI. Even MATCOM comes through at night and on weekends and they sounded pretty good but I'll keep my ears open and see next time I hear them.
Another possibility is that maybe you're in a fringe area and reception is not so good or maybe try turning off the AGC (Func + MAN).
3. Also, on the MO Channels, I don't always hear the start of the conversation. Picks up a few words into whatever they are saying. Sqelch is set ok.
I can only guess that in this case that's the point in which the scanner it's coming in the conversation, especially if you're scanning multiple other banks and sites. If not, give us more details to see if we can figure out if something is wrong.
