Originally Posted by akscanner
My concern is that I will not be able to scan the talkgroups in almr that I would like with the scanner, as I can't get the information on the talkgroup id's, etc.
Just adding or confirming what most have already mentioned earlier.....
Have you checked the database here for talkgroup IDs and info?:
http://www.radioreference.com/module...me=RR&sid=2447
It's a work in progress, especially since the majority of the system users have not or are still migrating to ALMR. Also, you can contribute to it if stuff you're looking for is not there! (hint, hint)
But anyway, you can also post in this forum what is the talkgroups you're looking for and maybe someone has an idea or might have the info but haven't posted it yet to the main database.
Is there a way to search through the system to find what I am interested in, or do I have to have the tg's pre-programmed into my scanner?
Yes, you can "search" through the system in ID Search mode. Just like doing a conventional freq search, just lock out what you don't want and keep on searching. Just remember, the talkgroup will need to be active and in use in order for the scanner to pick it up, just like a conventional frequency. You don't have to have the TGs programmed in order to hear them. The scanner will "tune" to any that becomes active.
