Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Receivers
All Other Receivers Discuss all other types of manufacturer’s receivers and scanners here.
Old 03-05-2009, 07:11 PM
StinkyB's Avatar
Question Fanon/courier
I had a friend give me an old scanner to look at, It's a FANON/COURIER COP-SCAN VHF 4ch crystal handheld scanner. Man this thing is old! Does anyone have any info on this scanner? there is a switch that has ON/OFF BYPASS, what is that for?
Danny Monroe
Pro-96
Pro-106
Old 03-05-2009, 11:05 PM
N8IAA's Avatar
I was at a garage sale last year and the guy gave me one of those including four xtals It doesn't scan for me, but the squelch pot doesn't work. It's on permanent open. ON/OFF Bypass locks out the frequency you are on. Damn thing has better audio on the conventional than my base scanner! I love it. I want to get a couple of other xtals for more monitoring. My model is the Scanfare VHF.
Larry
Pro-106, Pro-163, Pro-99, Lafayette 200A, ScanFare VHF 4Ch Xtal, FT-60R
Old 03-05-2009, 11:27 PM
N_Jay's Avatar
I forget the brand but had one in about 1981/82.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 03-05-2009, 11:31 PM
StinkyB's Avatar
This one works good. but the speaker has had it, it is very sensitive, the volume pot was dirty I cleaned it for him, I will try to find a small speaker to put in it. Ext speaker works good though.
Danny Monroe
Pro-96
Pro-106
Old 03-05-2009, 11:34 PM
StinkyB's Avatar
Default Squelch
Larry
I took apart his squelch pot and cleaned it also, it was very easy to work on.
Danny Monroe
Pro-96
Pro-106
Old 03-06-2009, 09:23 AM
N8IAA's Avatar
How did you take it apart? What did you clean it with? I would love to do mine.
Larry
Old 03-06-2009, 08:16 PM
If I remember correctly:
The bypass locks out channel 1 - so you can use something like a weather freq that stays on 24/7, while letting channels 2,3 and 4 scan.
Hope this helps.
Ken
Old 03-09-2009, 12:44 PM
N8IAA's Avatar
How did you take the radio apart. I would love to clean mine too.
Larry
Old 03-09-2009, 05:27 PM
StinkyB's Avatar
Smile POT Cleaning
Larry
It just snaps apart, no screws, there are four catches on each corner of the body halves,I just stuck my fingernail in between the two halves close to one top corner. Take the back off first, lift at the top first, the top silver piece is attached to the circuit board, and the bottom silver piece is glued to the front half only. The pots have nuts under the knobs, once you losen them they have enough wire to pull them out without unsoldering them, I had to bend the tabs on the pots to seperate them to clean them, the volume one has a snap ring that has to be removed in order to get it all the way apart. Used alcohol and some paper towel to clean them, be careful with the little contacts they bend easy, may have to use a pencil eraser to clean the contacts if they are real dirty. I have been doing this kinda thing since I was a kid, I am not afraid to take apart things and fix them, I can usually fix things that most people can't.
Danny Monroe
Pro-96
Pro-106
Old 03-10-2009, 11:55 AM
N8IAA's Avatar
Thanks for the info. I partially took it apart to check. Thanks.
Larry
Similar Threads
Fanon/Courier ScanFare VHF scanner N8IAA All Other Receivers 0 04-13-2008 05:24 PM
