Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Receivers
All Other Receivers Discuss all other types of manufacturer’s receivers and scanners here.
Old 04-26-2009, 08:08 PM
Exclamation vr-500 opinions
looking for opinions of yaesu vr-500. thank you.
Old 04-27-2009, 11:32 AM
eorange's Avatar
Read this for starters. I've had one since 2002 and probably will never part with it.
http://www.radioreference.com/forums...0-icom-r5.html
KA3FYU
Old 04-27-2009, 11:50 AM
datainmotion's Avatar
I have had one for years and the only issue I have had with it is the BNC-F connector on the chassis has broken loose from its solder joint. That was probably caused by an aftermarket antenna though.
Denver International Airport - Public Safety Online Scanner
Travelling to or through Colorado? Click here
Old 04-27-2009, 07:17 PM
MarkWestin's Avatar
I think that this almost 10 year old review from the "Strong Signals" web site would still be helpful:
Strong Signals - Yaesu/Standard VR-500 Review
I have had my VR-500 for about 5 or 6 years now, and while it is not a scanner, it is a good handheld receiver. My only problem so far is that I dropped it and bent/broke the BNC connector. The radio is very difficult to take apart for this type of repair.
For a contrast, I once owned a Yaesu VR-5000 receiver. Avoid the VR-5000 at all costs. It is (or was) FCC Class A rated (business use only which means that it generates a lot of noise) The VR-5000 is useless if used with a "back of set" type antenna. It used to like to lock up and you would lose whatever you had programmed into it (by hand, no software was available at the time).
KA1TIV
Old 04-27-2009, 08:32 PM
eorange's Avatar
Even though the VR-500 is marketed as a communications receiver, it does have scanning capabilities. It can scan up to 10 banks of 100 channels each.
Unfortunately, the scanning is slooow (12 channels/sec).
KA3FYU
Old 04-28-2009, 06:14 PM
bearcat012's Avatar
My only gripe is no PL/DPL. Other than that, a quick grab and go receiver. Leave the original antenna in the box, it is garbage.
AOR AR8600 W/P25 BOARD
AOR AR8200 MKIII
UNIDEN BEARCAT 796D
UNIDEN BEARCAT 898T
ALINCO DJ-X2000
YAESU VR-500
YAESU FT-8900
Yaesu FT-857
Old 04-29-2009, 03:39 AM
I had mine Yaesu-VR500 for about 5 years and i find it its does a good job for a small receiver and i agree with Mark on the Yaesu-VR5000 keep away from it at all cost to many problems with it and got rid of it.
Regards Lino.
ALINCO-DJX2000
AOR-3000/AOR-3000A/AOR-8200MK3
GRE-PSR500
ICOM-R3/ICOM-R20/ICOM-RX7/ICOM-PCR1000/ICOM-PCR1500/ICOM-PCR2500/ICOM-R9500
JRC NRD-545
KENWOOD TS-480SAT (2)
REALISTIC-PRO2035
UNIDEN-245/UNIDEN-396/UNIDEN-780
YAESU-VX7R/YAESU-FT8800R/YAESU-VR500
Similar Threads
New TAFL Search jfroot Eastern Canada Radio Discussion Forum 35 09-25-2009 10:22 PM
FS: Yaesu VR 500 JLAB Old Classifieds Archives 1 11-11-2008 06:12 PM
Win 500 % Win 500 Remote Server Access btritch Scanner Programming Software 0 07-16-2008 09:00 PM
gre 500 and win 500 trouble jonboy11 GRE Scanners 8 02-10-2008 12:27 AM
FS: Yaesu VR 500 Communications Receiver CommRX Old Classifieds Archives 1 09-08-2006 09:29 PM
