Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Receivers
All Other Receivers Discuss all other types of manufacturer’s receivers and scanners here.
Old 08-17-2009, 01:22 PM
Default Yupiteru MVT-7100 service manual?
Does this exist anywhere? My LSB-USB is way off freq and the master osc adjustment puts AM & FM right on but I need to find if there are separate adjustments for LSB and USB.
Thanks,
prcguy
Old 09-12-2009, 08:33 AM
I've never seen a service manual for the Yupteru MVT-7100 either online or in hard copy, not even a schematic. Shame, I could use one. One would think these must exist on some dusty shelf, somewhere in some service department, someplace.
The +USB / -LSB offset tuning thing is perfectly normal with the 7100, however. In practice mine runs between 1.4 and 1.8 kilohertz, using 1.6 kilohertz usually works well enough for memory entries. So lets say you want to program 11.175 MHz in USB mode. Program 11.176.6 instead.
Tuning in this fashion was pretty much an accepted practice among 70's shortwave radios, so they really weren't all that far outside of the box at the time. Still, a bit of a pain, though. You may find some signals need a touch of further fine tuning for good audio in sideband mode, too.
It is possible to create a spreadsheet or database which will calculate the values for you if your math is as bad as mine. The freqs still have to be manually entered, anyway.
Kind of a shame no one ever came up with a modification for adding an RS-232 interface to these fine radios. 1000 channels is a lot to program by hand.
Happy Scanning! - Ted
Old 09-12-2009, 09:28 AM
There's a ton of info here, even a crude schematic. I think you have to join to the view files:
MVT-7100 : Yupiteru MVT-7100
Even a frequency adjustment! Gosh, never tried. Also my photo guide to replacing the memory capacitor.
Old 09-12-2009, 03:21 PM
My USB and LSB were way off, I adjusted the main freq and USB came in very close but LBS is still about 4KHz off. I'm hoping there is a separate LSB adjustment.
prcguy
Old 09-12-2009, 05:28 PM
Yep I found that with my Yupi 7100 as well... USB was close to being spot on, about 0.3kHz (ie 300 Hertz) too high, but LSB had to be tuned about 2.6 KHz low. I just accepted that. What a wonderful receiver otherwise... wish I still had mine. Unfortunately they're as rare as hens teeth here, and prices & postage from the UK where they're far more popular are exhorbitant.
Similar Threads
996 Service manual? nydxa Uniden Scanners 1 05-01-2009 01:55 PM
PRO-26 Owner's or Service Manual Request bby Radio Shack Scanners 8 01-21-2005 11:33 AM
Is the Blocked Cellular Freq range on Scanners still needed? bear105 General Scanning Forum 52 12-05-2004 09:19 PM
great books: Latest Intelligence, pro-2006 service manual et wonderbread66 Old Classifieds Archives 0 09-07-2004 02:31 PM
Need PRO-2039 Service Manual bl86 Old Classifieds Archives 1 05-31-2004 07:43 PM
