Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Receivers
All Other Receivers Discuss all other types of manufacturer’s receivers and scanners here.
Old 09-07-2009, 12:55 PM
Default Yaesu VR-500 Recharge Any Batteries In The Radio The Easy Way
There is a caveat - WARNING:
ANY batteries you have in the radio will always be in charge mode when using an external power source and the radio is off. So that means if you have alkalines in use, it's going to try and charge them.
The charging current has been previously documented at 30mA.
This is very small. So small in fact, that I do not believe it is even capable of being able to fully recharge Yaseu's 500mAh or 700mah battery pack, let alone todays high capacity batteries.
You are better off using an external charger. The batteries I use are rated at 2900mAh, and I never use anything less than 700mA when charging.
No pictures to show the mod so I'll get long winded on how to do it
Take a piece of aluminum foil, and fold it over unto itself two times.
Make it very flat.
Make it so it's about the same width as a toothpick.
Remove the batteries from the radio.
You will notice on the bottom of the battery compartment, there is a flat metal tension spring that is used to make contact with the Yaseu rechargeable battery pack. Take the piece of foil you made, and slide it just under that spring. (If you made the foil just the right size, it will also be touching the spring on it's width side also.) Make it reach all the way to the negative battery spring on the side of the case. This is the tough part, to get it just right. Try to wedge that side of the foil near the back of the spring, near the very bottom of the spring, to hold it tight. Don't force it too hard or you may break the spring from its mount. The trick is to make that piece of foil just right, so it stays wedged both behind the bottom recharging spring and the battery recharging spring, it is laying very flat, and once it is fully installed, it is not protruding out of the bottom spring on the other side, where you first started inserting the foil.
This works great here.
At the very least it keeps me from removing and fully recharging the batteries somewhat, without having to re-open the battery compartment all the time.
My Last Web Project Was For This Sea Captain/Author:
http://dream12.com
Old 09-10-2009, 07:35 AM
tumegpc's Avatar
Default Charging NiMH batteris only-
"ANY batteries you have in the radio will always be in charge mode when using an external power source and the radio is off. So that means if you have alkalines in use, it's going to try and charge them".
I had the VR-500 a while back and if I remember correctly , there is a safer way. Using NiMH batteries , just score the battery label at the level of the radio contacts. Peel the label off exposing the metal casing. This should give you the ability to charge NiMH batteries and safely use alkalines.
Similar Threads
FS: Icoms, Yaesu, and RadioShack Handhelds... Driv3r912 Old Classifieds Archives 6 06-29-2009 06:29 AM
Darwin Cove Convention Centre grant Australia Radio Discussion Forums 8 10-31-2008 05:51 AM
EDACS Radio ID's Lake County IL - Programing on PSR 500 scannerfan3155 GRE Scanners 15 06-11-2008 10:17 PM
FS: Yaesu VR 500 Communications Receiver CommRX Old Classifieds Archives 1 09-08-2006 09:29 PM
Statewide Trunked System Information blantonl Virginia Radio Discussion Forum 0 09-11-2004 09:30 AM
