Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Receivers
All Other Receivers Discuss all other types of manufacturer’s receivers and scanners here.
Old 04-09-2007, 09:41 PM
mkewman's Avatar
Send a message via AIM to mkewman
Default Moto Spectra Issues- Won't turn on
I just got myself a motorola spectra a4 (VHF) and it's all connected up, but when i connect her to power, i get nothin.
this is my first motorola, and i've never done this so could there be something i missed?
the preceeding post in no way reflects the views of anyone except myself.
Old 04-09-2007, 10:06 PM
Send a message via AIM to Josh Send a message via Yahoo to Josh
is +12v applied to pin 5 of the 15 pin rear connector??
-Josh
Old 04-09-2007, 10:18 PM
SLWilson's Avatar
Send a message via MSN to SLWilson Send a message via Yahoo to SLWilson
Default Fuse?
Is there a FUSE in the hot wire fuse holder? Do you have a good ground?
Steve/KB8FAR
[B][COLOR="Navy"]I have my time in. Gonna stick around to see what happens next though !
Old 04-10-2007, 01:31 AM
NeFire242's Avatar
Yeah sounds like it most likely needs ignition sense.
Old 04-10-2007, 05:40 AM
mkewman's Avatar
i'm doing this on the bench, i have a rs power supply on her.
how do i provide ignition sense? she's got a couple loose wires coming out of the connection to the control head as well, is that the sensor?
Old 04-10-2007, 05:59 AM
SLWilson's Avatar
Question Paperwork
Uhm, I'd go to the Wiki or someplace and search out the diagram of the plug. Better get things pluged in right or something will get FRIED!!!!
Not sure on your Spectra, but, my Motorola has a Green & Ornange wire that runs the Control Head. The GREEN is constant hot to keep the memory volume and Freq set. The ORANGE is switched with the ignition for ON/OFF purposes so you don't run the battery down when you get out.
BUT, again, that's on MY radio. (I've got a Maratrac with a Spectra head) Better check yours out !!!!
Steve
Old 04-10-2007, 06:16 AM
mkewman's Avatar
yes the two wires are green and orange.
so what should i do with them? where can i get some installation info. batlabs isn't much help in terms of install info.
Old 04-10-2007, 06:42 AM
The Spectra needs 12 volt power on the heavy 2 wire connector on the back of the
radio. It also needs 12 volts applied to both the green and orange wires from the
control head. Some will power up with just applying the 12 volts to the green
wire and some don't. If it doesn't, then press the power button on the head for
a few senconds. It should power up.
Jim
Jim
Old 04-10-2007, 07:17 AM
mkewman's Avatar
it powers up great. thanks so much!
Old 04-10-2007, 03:58 PM
SLWilson's Avatar
Default Picture
Originally Posted by mkewman
yes the two wires are green and orange. so what should i do with them? where can i get some installation info. batlabs isn't much help in terms of install info.
Can you post a picture of your control head? I don't want to tell you what to do without first knowing what you have. If not, does the control head look somrthing like this?
Old 04-10-2007, 04:00 PM
SLWilson's Avatar
Thumbs up
Guess I missed where you got it working before I asked about a picture !!! Sorry !!!
Similar Threads
Kenwood radio perry23 Oklahoma Radio Discussion Forum 20 10-15-2009 11:39 AM
Programming Moto equipment wyldman Eastern Canada Radio Discussion Forum 4 02-23-2007 12:42 AM
Moto Equipment Questions/What do I have? bonus1331 Motorola Forum 5 01-25-2007 08:26 AM
LaSalle county sheriff snowbird Illinois Radio Discussion Forum 10 07-10-2005 08:30 AM
Found this on the Uniden website duckbird Uniden Scanners 0 01-13-2005 07:35 AM
