Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Receivers
All Other Receivers Discuss all other types of manufacturer’s receivers and scanners here.
Old 07-19-2007, 10:15 AM
redmonds's Avatar
Default vr-120 Step Size
I am trying to set up the Auto Step Size option on my VR-120 and I'm not sure what all the step sizes are for the whole band from 5 KHz to 1300 MHz. If someone could assist me with where to find this information, it would be greatly apprceated.
Thanks,
Rodney
VR-120 "Nut"
Old 08-29-2007, 12:02 AM
Mike_NZ's Avatar
Send a message via ICQ to Mike_NZ Send a message via MSN to Mike_NZ
Post
Hi there,
All that info is on page 41 of the user manual.
Cheers,
Mike.
ZL3TPQ,
AREC Comms Operator.
Old 08-29-2007, 06:44 AM
wa8vzq's Avatar
This is from a post that I made on the VR-500 yahoo group on the same subject a few years ago.
Please note that since the VR-120 doesn't have single sideband reception you can skip those references. However, you may be interested in the SWBC band limits.
The VHF & UHF band plans are much more detailed than I laid out. I only accomodated band segments of interest to me. You should look at the individual band plans and make your own determinations of which steps to use depending upon your listening interests.
The VR-500 can not handle all of the band plan channel steps correctly. That is why the segement - 144.00000 nfm 10 khz 2 meter ham - is set to 1/2 normal channel step. This segment is used in 20 KHz steps but the VR-500 won't step correctly here.
The rule for the VR-500, and I'm assuming the VR-120, is that the frequency divided by the step size needs to yield an integer dividend. In other words the answer has to be a round number with only zero's after the decimal point. If the answer ends in .500 or .2500 or something other than .0000, the scanner won't step correctly. This is true for many scanners, not just Yaesu.
Regards
Dan
0.10000 am 1 khz aeronautical/marine beacons
0.53000 am 10 khz NA domestic broadcast
1.80000 lsb .1 khz 160 meter ham
2.00000 usb .1 khz hf utility
2.30000 am 5 khz 120 meter SWBC band
2.51000 usb .1 khz hf utility
3.20000 am 5 khz 90 meter SWBC band
3.40000 usb .1 khz hf utility
3.50000 lsb .1 khz 80/75 meter ham
4.10000 usb .1 khz hf utility
4.70000 am 5 khz 60 meter SWBC band
5.07000 usb .1 khz hf utility
5.73000 am 5 khz 49 meter SWBC band
6.30000 usb .1 khz hf utility
7.00000 lsb .1 khz 40 meter ham
7.30000 am 5 khz 40 meter SWBC band extension
7.60000 usb .1 khz hf utility
9.25000 am 5 khz 31 meter SWBC band
10.1000 usb .1 khz 30 meter ham
11.5000 am 5 khz 25 meter SWBC band
12.3000 usb .1 khz hf utility
13.5600 am 5 khz 22 meter SWBC band
13.9700 usb .1 khz hf utility
15.1000 am 5 khz 19 meter SWBC band
15.8000 usb .1 khz hf utility
17.4000 am 5 khz 16 meter SWBC band
17.9000 usb .1 khz hf utility
21.4500 am 5 khz 13 meter SWBC band
21.8000 usb .1 khz hf utility
25.67000 am 5 khz 11 meter SWBC band
28.00000 usb .1 khz 10 meter ham
29.60000 nfm 20 khz 10 meter ham
50.00000 usb .1 khz 6 meter ham
53.11000 nfm 20 khz 6 meter ham
54.00000 wfm 100 khz tv/fm broadcast
108.00000 am 25 khz vhf aviation
144.00000 nfm 10 khz 2 meter ham * set to 1/2 normal channel step
146.43000 nfm 15 khz 2 meter ham
156.00000 nfm 25 khz marine etc
157.47000 nfm 15 khz railroad etc
162.00000 nfm 12.5 khz us govt
222.20000 nfm 20 khz 1.25 meter ham
225.00000 am 25 khz dod aviation
406.00000 nfm 12.5 khz us govt
442.00000 nfm 25 khz 70 cm ham
450.00000 nfm 12.5 khz broadcast remotes
451.00000 nfm 25 khz commercial
851.00000 nfm 12.5 khz
900.00000 nfm 30 khz
1300.00000
Similar Threads
Pro-96 confirmation on step size feedbak Radio Shack Scanners 1 04-26-2007 09:20 PM
Setting Step Size to Allow Full Frequency Entry bc780l Uniden Scanners 3 02-16-2007 08:29 PM
BR330T Step Size fuzzymoto Uniden Scanners 2 05-12-2006 01:52 AM
Pro 2096 Step Size Frustration ronmchandler Radio Shack Scanners 3 06-22-2005 01:23 AM
Pro-96 Step Size? Forts Radio Shack Scanners 0 12-22-2004 11:28 PM
