Alinco DJ-X3 - Cable info?
buttsrob
Colton, SD
Hi,
I just purchased an Alinco DJ-X3E. Seems like an interesting scanner with some unique capabilities.
Does anyone have information on the programming cable?
For example...is it a simple TTL interface? Would the Icom OPC-478 work??
The cloning software is free...
I think I'd rather make a cable than spend $40-$60 for one.
Thanks!
RMB
pyeman99
Redruth UK
Seen a diagram,will track it down & get back to you.Keith.
buttsrob said:
Hi,
Thanks!
RMB
buttsrob
Colton, SD
Thanks!
FYI all - I found out that it uses the SAME cable as Icom Scanners (IC-R2/R3 and the T90A). I think it's the OCP-478.
Anyway, my cable for the T90A works just fine.
Unblocked coverage (HF to 1200 MHz) and Inversion descrambling works really nice here in Iraq.
RMB
