Well, my BC396 has really got me into the Fire Tone bit big time! I have acquired a few Plectron 720's and would like to set them up for some local stuff. The frequency is controlled by a drop in crystal, similar to the old crystal scanners, and I can order the crystals from a couple sources. I even figured out the formula, it is pretty simple (For Highband, just subtract 10.7 from the actual freq and then divide the remainder by 9).
These R720's use tuned coils for the tones however. For that I have a few questions I will be researching:
Is there a fairly simple way of tuning them to different tones than they are on now?
If they are so tunable, is there a limit as to how far I can retune one? For example, on of the tones is now set to 1600.0 Hz according to the ,lable and prior user, can it be adjusted to say 881.0?
If I am able to make these work for me I plan on replacing the old RCA jack antenna connector with a BNC as I did with my existing units.
