Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > All Other Scanner Manufacturers
All Other Scanner Manufacturers The forum to discuss all other scanner manufacturers not listed above.
Old 10-29-2012, 7:36 AM
thebigphish's Avatar
Default unamplified output for Communistarr TA2001
I understand that the company is no longer in service, after the owner's passing...but is there anyone out there who knows where I can tap into the circuit board on this unit to find unamplified audio to feed into a PA system?
I'm couple of hours into specific chip lookups, based on what I see inside, but I'm not having any luck.
Old 11-03-2012, 9:06 PM
What on earth is a Communistar TA2001? I did a Google search, and it came up with one hit - THIS thread!
Radio Shack coax doesn't go bad. It's born bad.
Old 11-09-2012, 5:25 PM
BigFish
Still out there .........?
Yes, Communistar shut up shop in the mi-1990's
There are 3 or 4 points you could tap audio from - but which one is best suited is going to be determined by which input you choose to drive the PA through, so, how are you intending to drive the PA?
- through a line input balanced or unbalanced (anyhow, line level should be around 4dB/1.5v)?
- or, through a mic input (and would that be a 600Ohm mic input, or some other impedance)?
