Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas Discuss all types of antennas used to transmit or receive on amateur radio equipment. This includes base, handheld, mobile and repeater usage.
Old 10-28-2012, 9:20 PM
Fury853's Avatar
Question Painting a whip antenna
I am working on blacking out some things on my SUV and was thinking about blacking out my Ball mount, spring, and whip antenna! Does anyone have any ideas on what I could do? i thought about spray painting it. But would that work on the stainless steal? also would that affect the signal any?
"Don't worry about the world coming to an end today. It's already tomorrow in Australia."
SVFD LT 8-2, CF10, KJ4PGD
Old 10-28-2012, 10:30 PM
n5ims's Avatar
This has been asked a few times here on RR so instead of rehashing this topic, here are some links to those so you can use their knowledge and experience...
paint an antenna?
Spray painting antenna
Spray painting an antenna effect performance?
Can you spray pain an antenna?
Paint / Coatings for Antennas
Hope one or more of those will completely answer your question as well as others you may not yet have thought to ask.
Old 10-28-2012, 11:15 PM
ridgescan's Avatar
"Plasti-dip" or black shrink tubing.
http://www.plastidip.com/
Unidens BC785D, BC350A on a D130J
'54 Hallicrafters SX-88 #127, Icoms R71A&R75 on 50' random wire @40' SW will never die
RS Pro 2066 in the truck to glassmount tribander
Old 10-29-2012, 4:40 AM
I've used plastidip on a few things. It'll work fine on the ball but I wouldn't recommend it for the whip or spring because the smooth steel surface and constant flexing will cause it to peel off pretty quickly. Heat shrink is a good option for the whip. You can get 4' and 8' lengths from many sites. And just spray paint the spring.
Sent from my Galaxy SII using some Tappity Talkity thing.
Old 10-29-2012, 4:54 AM
gewecke's Avatar
Thumbs up
Flat black rustoleum works well for this.
73,
n9zas
Old 10-29-2012, 10:00 AM
The only suggestion I'd make is to not paint insulators.
- 'Doc
Old 10-29-2012, 8:55 PM
Fury853's Avatar
Some good suggestions! Does anyone have any pictures of your painted antennas?
Old 10-29-2012, 9:56 PM
ridgescan's Avatar
Well mine for one already came black and is a scanner antenna so not quite the same as what I think you have.
The Plasti-dip site has rubber products as well that will work on the steel.
Old 10-30-2012, 8:04 AM
jhooten's Avatar
If you dip or heat shrink it recheck the tuning when done.
If you want to paint it use this first: Dupli-Color :: Self-Etching Primer
Jerry
I read it on the internet, so it must be true.
Old 12-30-2012, 11:42 PM
I once used electrical tape on a 9 foot whip, then just sprayed it with flat black paint. Worked well with no issues.
