Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas Discuss all types of antennas used to transmit or receive on amateur radio equipment. This includes base, handheld, mobile and repeater usage.
  #21 (permalink)
Old 12-22-2012, 7:42 PM
Wiki Admin Emeritus
If it's a 6 meter duckie like the one Comet sells (actually it's a tri-bander) it's possible (I've done it myself, but I was living in a 4 story condo at the top floor at the time, so I had a height advantage...). However with a small duckie like what comes with most handhelds - not completely out of the question, but pretty close. Those things are so lossy at 6 meters that a wet noodle might almost work better
  #22 (permalink)
Old 12-23-2012, 12:15 AM
w2txb's Avatar
Thumbs up
Check out the Maxrad line... good stuff.
"Non Impediti Ratione Cogitationis"
  #23 (permalink)
Old 12-31-2012, 11:24 AM
KC2OBW's Avatar
Send a message via AIM to KC2OBW
So I ended up buying the Diamond M685SNMO. Received it Friday afternoon and had it on the car before it got dark. Now all I have left to do is mount the radio and tune the antenna. Will post some photos once I can.
PRO-197, XTS3000, Astro Saber HT1250, MT2000, HT1000, FT60R, VX8GR, UVD-1P(2/1.25), TM741, FT8800R, DR235T.
WQOK964
  #24 (permalink)
Old 01-03-2013, 8:41 AM
MFJ makes a Firestick type also. Not sure what part of the band it's cut for, I just bought 2 and their adapter to make a horizontal 1/2 wave diapole antenna for mountian topping.
John
  #25 (permalink)
Old 01-21-2013, 8:41 PM
KC2OBW's Avatar
I ended up going with the diamond with the NMO. Antenna works great!
WQOK964
  #26 (permalink)
Old 01-21-2013, 11:47 PM
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
Originally Posted by potbellyperch
can you hear dx on a rubber duckie ant???? outside i mean not in the house
thanks
I haven't heard anything on 6M, but I can pick up a 29.620 repeater from New York state in Arizona on my PSR-500 with the RS 800MHz duckie.
  #27 (permalink)
Old 01-22-2013, 8:39 AM
k3td's Avatar
I wish there were active 6 meter repeaters here in central Texas. 6 FM is a lot of fun. Here is a link to a wide area 6 meter repeater in Syracuse that is cross linked to a 10 meter machine at the same site, maybe you can work through it if you get some tropo enhancement?
The KD2SL 6m Repeater – Syracuse, NY | How a 6 meter repeater came to be…
Tad, K3TD
EM10dq
  #28 (permalink)
Old 01-22-2013, 9:10 AM
KC2OBW's Avatar
I'll have to program that in and see if I can bring it up.
WQOK964
