Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas Discuss all types of antennas used to transmit or receive on amateur radio equipment. This includes base, handheld, mobile and repeater usage.
Old 12-04-2012, 12:40 PM
Default Gasket/Seal for Diamond Mobile Antenna
I have a problem I have been unable to solve. I have a NMO mount on my Outback and normally use Larsen antennas. I bought a 6m Diamond antenna, used, and it has no gasket like the Larsen's have. The bases are different between the two antennas so I can't use the gasket from the Larsen antennas. What does Diamond use, if anything, between the car and the antenna? I haven't had good luck with trying to find an O-ring that fits. Recommendations anyone?
Old 12-04-2012, 1:32 PM
n9mxq's Avatar
COntact Diamond, they are always helpful. DiamondŽAntenna Click "Customer Order Parts" in the upper right corner of the page.
Gene
If you can't post something helpful, don't post.
Old 12-04-2012, 3:23 PM
k3cfc's Avatar
About any auto-parts store will have an assortment of loose o-rings
K3CFC
Old 12-04-2012, 3:31 PM
mmckenna's Avatar
The flat seals that go under the "chrome nut" style antennas should work for you. They go around the NMO outer ring and are about a 1/4 inch wide. If you can't find one of these, you could make one your self by getting some rubber gasket material or a piece of inner tube and cut your own.
If you really get in a jam, let me know, I have a bunch and I can mail you one.
Old 12-04-2012, 8:51 PM
I've used generic rubber o-rings I found at the local plumbing supply store.
One thing to remember is the thread pitch of the Diamond antenna is slightly different than the Larsen so even though the Diamond will screw on a standard NMO mount, the threads will slowly bind and you may have difficulty getting the antenna off again.
Old 12-04-2012, 9:52 PM
Larsen RGNMOANT - $4.95 : The Antenna Farm :: , Your Two Way Radio Source!
fineshot1
NJ USA
Old 12-04-2012, 10:22 PM
mmckenna's Avatar
Yep, that's them. Or these: Maxrad MMGSK - $4.95 : The Antenna Farm :: , Your Two Way Radio Source! Those come 6 to the package for the same price as the Larsens. Either will work just fine.
