Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas Discuss all types of antennas used to transmit or receive on amateur radio equipment. This includes base, handheld, mobile and repeater usage.
Old 02-19-2013, 5:14 PM
Default Installing an NMO cb whip next to my Ham whip
Hi folks, I am going to be installing a Larsen CB whip on my roof, which already has a Larsen 2/70 mounted in the center. I was looking for suggestions on where to mount, considering the proximity of the existing antenna.
Should I mount it centered between the Ham antenna and the end of the roof? Or should I mount it closer to the rear of the roof, leaving more space between the antennas?
Thanks,
KJ6VWH
Old 02-20-2013, 5:59 PM
Here is a picture of what I'm working with:
Old 02-20-2013, 8:24 PM
If it were mine, I'd put it close as possible to the 3rd brake light. Far enough away so that the vehicle's wiring isn't fouled. Or stick it on one rear corner.
- 'Doc
Old 02-20-2013, 8:29 PM
n9mxq's Avatar
I agree with Doc. Right in front of the third brake light.
I had 3 antennas inline like that in my caravan. Larsen 2/70, 2m 5/8 wave and a GPS puck.
Anywhere there was a light or panel I could pull to get roof access and not still through the headliner ;-)
Sent from my iPhone using that Tapatalk thingamabobber.
Gene
If you can't post something helpful, don't post.
Old 02-21-2013, 5:25 AM
n9mxq's Avatar
You can kind of see the antenna arrangement on the van in this picture from 12-09...
Edit.. nevermind, can't get the photo to load... dangit...
Gene
Old 02-24-2013, 11:33 PM
n9mxq's Avatar
Picture attempt #2
Gene
