Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas Discuss all types of antennas used to transmit or receive on amateur radio equipment. This includes base, handheld, mobile and repeater usage.
Old 02-21-2013, 12:02 AM
VE3JSO's Avatar
Default mfj-2286
hi i just bought the mfj-2286 for my first antenna and i am going to be useing it with the tripod that is also from mfj and i am a little unsure on the proper set up for the counterpoise i know that i need to attach the four copper wires around the base block and the other end of the wires that is connected together into one so i am not sure if i connect that part to a ground rod or what? any advice and does any one that has the same antenna as me have any pics of it fully set up that could help me.
thanks 73
jamie
- Jamie VE3JSO
Pro 90, Pro106, KENWOOD 450S, yeasu ft-60r
http://www.starrsoft.com/software/win500/
Old 02-21-2013, 10:48 AM
Go here: MFJ 2286 Big Stick Vertical Antenna Product Reviews
Three hams have reviewed the 2286 and gave details on how they used it. One didn't even bother with the counterpoise and made contacts.
A counterpoise is not usually connected to a ground rod unless there are specific instructions to do so. They are laid out on the ground to give the antenna the other half of a dipole. A vertical is merely a dipole where the ground radials are the other part of the antenna system.
Old 02-21-2013, 2:10 PM
VE3JSO's Avatar
thanks n5twb for the link and reply
73
- Jamie VE3JSO
