Two radios (2m and 70cm) with one antenna using this?
Yep, that is exactly what that product is for, VHF radio and UHF radio into a dual band antenna, OR a dual band radio into separate VHF and UHF antennas, she'll work either way.
In your case, connect the common port to your dual band antenna. Connect the 1.3 - 225MHz port to your VHF radio, and the 350 - 540MHz port to your UHF radio.
