Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas Discuss all types of antennas used to transmit or receive on amateur radio equipment. This includes base, handheld, mobile and repeater usage.
Old 03-10-2013, 3:18 PM
Quickcall's Avatar
Default Two radios (2m and 70cm) with one antenna using this?
I've got one 2 meter radio and a 70cm radio, if like to have them on one dual band antenna. Would a OPEK DU-500UF - VHF UHF Ham Radio Duplexer work for a setup like this? Maybe something else?
OPEK DU-500UF - VHF/UHF Indoor Duplexer DU500
Ricky, life isn't about getting drunk and eating chicken fingers all the time"
Old 03-10-2013, 3:57 PM
mmckenna's Avatar
Yep, that is exactly what that product is for, VHF radio and UHF radio into a dual band antenna, OR a dual band radio into separate VHF and UHF antennas, she'll work either way.
In your case, connect the common port to your dual band antenna. Connect the 1.3 - 225MHz port to your VHF radio, and the 350 - 540MHz port to your UHF radio.
