rtl2832u Amplifier
RelativeCode
I don't know is this correct place for this question or not?
I am using a dongle (rtl-sdr rtl2832u), I've fixed the antenna on the roof, for long distance from the roof to the room, should I use the amplifier.
So, as you can see on photo's this is my installation process.
1- In Line Amplifier, amplifier with 950 to 2400 MHz frequency band.
2- 24V Switching Power Supply.
3- 18V voltage regulator circuit with noise canceling circuit.
4- 35 meters wire.
5- Antenna 1090 MHz.
But I think part of my job is wrong.
I would also like to know your opinion and your advice.
