I have a Workman fiberglass antenna that can comer apart to be tuned. I had decent 2m SWR, and lower .70 before I started. I tested the bands and found that the antenna worked better at the bottom of the bands, so I assumed it was too long and took an inch from the top. That was probably a bad idea, but as it is now, I am sure I am not handing this tuning properly.
I have a flat SWR from 339 - 442, at 442 is where is stats to climb, and it is still pretty good up to almost 443, but way off by the time I get to 444. I now have messed up 2m, so that is why I know I did something wrong
The inside of the antenna has what appears to be a single wire in the lower section that I can't get at easily, the part I can get to starts with one long coil at the lower section, and a shorter coil towards the top, with a straight piece coming out of the top where I cut at least two inches off. I then compressed the long coil a little, and ended up with what I have now. I would like to push up the band in .70, and regain my 2m operation , which is far off from where it should be.
Does anyone have enough experience with antenna design to offer some advice on where to take it from here?
