Much depends on where you live. In a city or area with hills/mountains, a 1/4 wave antenna is many times the best choice. If you live in an area that's flatter, not a lot of obstructions, a 5/8 wave antenna may be your best choice.
In either case, Larson antennas are among the best available and their price is reasonable.
I use a Comet SR 4 X 4 because I need a wide banded antenna for several bands, so that's the best for me, but for strictly 2M or 2M/70 CM, Larson would be my first choice.
I use a 1/4 wave Larson in many cases as I am in a hilly area that has repeaters quite high above the valley.
If you give more info about how you want to use the antenna such as for repeaters or simplex and what kind of area you will be using the antenna in, you might get a more targeted answer.
In any case, the Larson is about the best going. Be careful when looking at the gain specs on antennas. Most give the gain in DBI, not DBD which is a more realistic number.
Make sure you mount it in the center of the roof or towards the front of the top if best pattern is desired. Good mechanical connection between the mount and car body is a must also.
Many times a Comet or Diamond antenna cost more for the name. Professional users like Larson, they work well, excellent construction and the price is right. There is no magic antenna, only good one's and bad one's. Placement on the vehicle, proper installation, grounding doors, hood, tail pipes, to the vehicle body and frame (if your vehicle has a frame) and choosing the right wavelength are some of the more important things to consider.
73's John
