Greetings,
I have been wondering if a remotely located or antenna-mounted outdoor type antenna tuner such as those sold by SGC, MFJ, Icom and others can be used with a CB radio transceiver that puts out 4 watts AM and 12 watts SSB?
If so, how would this be set up? Some of those tuners need to be connected to a compatible like-brand HF transceiver I think in order to use the remote tuning feature. Others don't (I think).
I was even thinking of trying to connect both an HF ham radio transceiver plus a CB radio transceiver to the same remote tuner and antenna simultaneously and use a coax switch to switch back and forth between the two to share the same antenna with tuner. Would something like this work?
