KD8NIV
As some of you no I have power lines running through the back yard, and out front as well but against the mountain side....no tree's in the yard I can use, and on a small lot as well.....anyways, I have a G5 up which is a 102' long , and is up 32' and its in a Vee shape over the top of my trailer, and have the legs coming out in a angle on both sides as far as I can go, have been able to use it on 20m and 12m bands.........and that's as far as I can go out with the legs....
So, not sure if I should cut the G5 down and use it as a Jr size dipole, or not...I do have the room to hang a Jr out flat and not be a problem.....
Also, going to buy a MFJ 939Y tuner, since it will work on a lot of different radios, and for the price.....not planning on running a amp here anytime soon, so think this is all I need for now....
Also, going to change out some coax I'm using too..
Also have a Imax 2k which has good swr on 10, 12, 15m bands, which haven't used it much..
Also have a homebrew 40m wire up 20' which seems to do a good job as well...
Should I cut the G5 down to a Jr size dipole, or what you guys suggest ?..
