Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas - For discussion of all amateur band designed antennas and related accoutrements. This includes base, handheld, mobile and repeater usage. For commercial antennas on the amateur bands please use Commercial Radio Antennas below.
Old 04-22-2017, 9:59 PM
davidzimmerman's Avatar
Default 2M\440 Shot Glass Mobile Antenna
who makes the BEST shot glass antenna? i just got a 2006 Ford Escape i run 3 of them now 2 are 700\800 MHZ 1 for Scanner 2nd for 700\800 MHZ Motorola XTL-5000,last is UHF for my other XTL-5000.i have a FT90 Dual Band radio i got new maybe 10+ Years ago need a good shot glass 2m\440 for the roof.
Old 04-22-2017, 10:45 PM
jparks29's Avatar
Maybe if you used standard terms instead of 'shot glass' we'd know what the hell you're talking bout...
I assume you mean low profile.
You're not gonna find a dual band phantom style antenna.....VHF is crap in those antennas, and UHF isn't much better....
A 1/4 wave on 2m is a 3/4 wave on 70cm, just an FYI, it resonates quite well....
The only good cat is a stir-fried cat!
Old 04-23-2017, 1:35 AM
mmckenna's Avatar
For VHF, they all suck equally. Some might suck better (worse?) than others, but they all suck.
I haven't see any of the major antenna manufacturers make a "dual band" phantom style antenna, but I know some of the Cheap Chinese Antenna manufactures (located right next door to the CCR factories!) do.
Trying to squeeze 19" of radiating element into 2 inches doesn't work. Yeah, you can make it resonate on a VHF frequency, but you can do that with a dummy load, too.
What I can tell you about the VHF side of these things:
I know a few people that have tried these VHF phantom/low profile/shot glass/soup can, etc antennas.
All of them. Every single person that I know who has tried one, has regretted it. In fact I've had several people offer me used ones for free, that's how much they value these things.
- they are -very- narrow bandwidth, like 1MHz, maybe a bit less. Not going to cover the entire 2 meter band. That is IF they are tunable. Some of the Chinese ones aren't.
- they don't handle much power. 50 watts max. Anything more and they overheat (kind of like a dummy load).
- they are poor performers. Less than 0 gain (kind of like a dummy load).
Where they do work:
If you've got one frequency or a few that are very closely spaced. If you are within spitting distance of the repeater.
Honestly, it would be cheaper to just by a 50Ω dummy load and mount it on your roof. It would work as well.
On UHF they work a bit better. Cramming 6" of radiator into a 2" tube isn't quite as sucky. As you know, they work pretty well on 700-800MHz since it's not a stretch to put 1/4 wave inside the antenna and make it work. In fact, I have one and it actually works better than 1/4 wave.
But, if you've got to have one, at least let us know what you discover.
Old 04-23-2017, 5:43 AM
thanks for everyone's help what about a good LOW PROFILE (shot glass) 2M VHF antenna? i have a low Clearance Garage Door don't want to put a L bracket on the fender.
Old 04-23-2017, 6:56 AM
n9mxq's Avatar
Sorry, but they don't exist. They're a compromise antenna at best. You can't cram enough wire in to make it work worth a dang. If you're driving a pickup, I'd recommend a fold over style antenna in the stake pocket. Still get a full sized antenna, but easy enough to fold down to get in the garage.
Gene
Transceivers, receivers, and SDR! Oh My!
Old 04-23-2017, 7:00 AM
Default Low profile antenna
I have a friend who is an electrical engineer that tried one of these. The range in miles is lower than the SWR reading. As has already been said, forget 2 meters. A cheap quarter wave will out perform any low profile junk.
Old 04-23-2017, 8:11 AM
As already posted above, you just ain't gonna find one that works!!! I tried one of the CCRs, (rather CCAs) and the swr was over 3, and distances at most was something like 2 1/2 to 3 miles with very weak signal. Go with a standard quarter wave and be happy.
FT-2900R, FT-101EE, HTX-202, IIC-2AT, BTX-121, UV-5R, KT-7900D
Old 04-23-2017, 9:07 AM
thanks everyone guess i'll do the L Fender Bracket for the antenna
Old 04-23-2017, 9:31 AM
What's your clearance issue, couple of inches?
Old 04-23-2017, 10:54 AM
maybe under 8 inches
Old 04-23-2017, 11:17 AM
mmckenna's Avatar
A simple 1/4 wave whip will bend over and spring back.
Stico makes a very flexible whip. So does Panorama antennas.
Old 04-23-2017, 4:36 PM
jparks29's Avatar
Yup. Even comet has a cellular look alike dual band antenna..
My vote is still for a thin 1/4 wave whip or a heavy duty 1/4 wave whip on a spring....
Believe it or not, sometimes longer whips are better as they flex more......
Comtelco A1511, NMOWBQCFT, etc
Old 04-25-2017, 6:57 AM
i used the L Fender bracket works great
Old 04-25-2017, 2:50 PM
I assume the criteria to define "best" is "Which one survives best in a high speed rollover?"
I think the April 2011 issue of QST carried full test results for those.
Old 06-02-2017, 9:18 AM
Wait, you're saying a 1/4 wave 2m antenna will suffice as a dual-band?
Sent from my iPhone using Tapatalk Pro
Old 06-02-2017, 9:39 AM
mmckenna's Avatar
Yes. A 1/4 wave VHF antenna tuned for the 2 meter amateur radio band is a 3/4 wave antenna on the 70 centimeter band. I ran a dual band amateur radio like this for years.
I trimmed my antenna for low SWR on 2 meters and it had even lower SWR on 70 cm.
The trade off is that the radiation pattern for a 3/4 wave antenna is such that more energy is shot up at an angle than out at the horizon. Where I live with hills/mountains on 3 sides and the ocean on the other, this worked just fine.
I'd occasionally swap in a Larsen NMO-2/70sh (a purpose built dual band) and I really didn't notice any difference in performance, although that's because of my specific location.
Out on the plains of the central USA, this might not be an ideal solution for UHF work, but it will work.
Plus, if you shop around, it'll cost you a total of about $9.00.
Old 06-02-2017, 10:03 AM
I actually have one but just recently purchased a dual band radio. I'll use it in the meanwhile as I'm probably gonna be TXing mostly in 2m. Thanks!
Old 06-02-2017, 10:24 AM
mmckenna's Avatar
I think you'll be happy with it.
Old 06-02-2017, 10:39 AM
Awesome. I appreciate the help.
Old 06-05-2017, 7:47 PM
Look into "Compactenna"
They have the widest claimed coverage and performance
Available at Universal Radio
